Got It Back Together
Old Feb 20, 2010 | 11:44 PM
kdfishe43's Avatar
kdfishe43
Talking Got It Back Together
i finally got the clutch put in today. it was quite a job but we got it done. the rear main was leaking so i fixed that and the pilot bearing was shot so i replaced it with the kevlar one. she drives alot better now and actually hooks up. just wanted to thank everyone for all the helpful info
Old Feb 21, 2010 | 09:33 AM
Ziggy.'s Avatar
Ziggy.
Glad you got it all back together bud, what did you find out about the shifter?
Old Feb 21, 2010 | 10:49 AM
kdfishe43's Avatar
kdfishe43
the two little yellow fork things in the bottom of the base of my shifter, as you probably know already, have a flat side and a kind of tapered side with the tapered side supposed to be pointing towards the top of the shifter. well one side had the tapered side pointing up and one side had the flat side pointed up so i guess it just had it in a bind. i took it back off and finally figured out how it was supposed to go and it works great
Old Feb 21, 2010 | 10:55 AM
Ziggy.'s Avatar
Ziggy.
Good deal man, I'm glad its all working good for you, I forgot to ask which clutch was it you got from Valair?
Old Feb 21, 2010 | 10:55 PM
kdfishe43's Avatar
kdfishe43
i got the organic 400 when i took it and the flywheel to tennessee clutch in nashville he guessed it to be good to 450 and since im not pushin anywhere near that i think i'll be alright
Old Feb 21, 2010 | 11:04 PM
Ziggy.'s Avatar
Ziggy.
You ought to be fine, i've still got to tinker with mine since I did the Double Disk install, when and how the pedal engages is a *******, and I dont like it. I'm going to pretty much re-engineer the linkage with an adjustable cam plate to get it the way I want it.
Old Feb 22, 2010 | 01:47 PM
kdfishe43's Avatar
kdfishe43
yeah i drove a buddy's pull truck the other day with a dual disk south bend and it was terrible. i do have another question though, he said not to drive it too hard for about a hundred miles so i drove easy for about 150. i turned my chip back up today and when the turbo spooled in 6th it still felt like it was slipping alittle. not bad but just that scary feeling you know? anyways when we put it in a guy i know said slip it alittle then let it cool down so i did. i was just wondering if it takes it awhile to grab all the way or what
