jsut some help
Old Feb 20, 2010 | 06:39 PM
rfgarvey37's Avatar
rfgarvey37
Smile jsut some help
have a 96' f-150. 5.0l 5 speed manual. has 4" lift and 33x12.50's. would anyone know maybe some bolt on mods for better gas mileage or pulling. and even jsut some extra horses under the hood? appreciate any ideas...
Old Feb 20, 2010 | 07:44 PM
skyfox10's Avatar
skyfox10
Classically, people look for headers and less restrictive exhaust. better flowing intake, heads, and cam.
Althought my question to you is. What transmission and rear gear ratio are you running?
Old Feb 20, 2010 | 09:06 PM
rfgarvey37's Avatar
rfgarvey37
uhh on that i not reallie for sure. will check it out get back with the results. and as far as exhaust it has a custom exhaust. stock ex. manifold though. anddoes any sell towing mirrors for this year truck
Old Feb 21, 2010 | 12:00 AM
trvcampbe's Avatar
trvcampbe
Gas mileage? With 33x12.50s..Good Luck..I have a 1987 f150..I have converted to Mass air,dual electric cooling fans,k&n,underpulleys and 3g 130 amp alt..All i get is 15/19..Used to get about 12/17..
Old Feb 21, 2010 | 06:50 AM
TexasGuy001's Avatar
TexasGuy001
Your best options are going to be regearing the diffs to 4.10 or 4.56. The gears are really the most important thing. A good free flowing exhaust with a straight through muffler will also help things.
A good tune up with fresh fluids and filters will also help.
You could add a hotter TFI coil like MSD or Accel with some good spark plug wires.
The other beneficial mods are mostly going to be internal like cam or heads etc.
Don't waste your money on CAI, chips, throttle body spacers, KN etc.
Old Feb 21, 2010 | 10:03 AM
preppypyro's Avatar
preppypyro
Big question is, how much do you want to spend? I mean if you wanted to dig into your motor a little bit you could throw on a set of heads, and a cam, and that would help. Add some headers and free flowing exhaust, and that would help.
Lots of good deals on ebay for parts too!
Old Feb 21, 2010 | 02:01 PM
rfgarvey37's Avatar
rfgarvey37
well thanks for the input. i am only gettin like 8/12 mpg and just wanted a bit more. and i not looking to dig into the motor yet but in the future. and texasguy001, where could i look for some gears? and bout how much, and would that take away from my hwy speeds?
Old Feb 22, 2010 | 06:14 AM
TexasGuy001
The right gear ratio will actually make your truck drive better around town and on the highway. Since your truck has overdrive lower gears won't hurt you on the highway. The gears are the only way to really compensate for bigger tires. You can get gears from Summit and Jegs. You might also want to look on Ebay for a ring and pinion set that someone bought but never got around to using. You could go with used gears, but your probably better off with new ones. Just make sure they are for an 8.8 rear end. It will probably cost several hundred bucks to have it done though. I didn't see it mentioned if your truck is 2wd or 4wd. If its 4wd just regear the rear first and then save up for the front. Just don't run 4wd until the front is matched up.
Old Feb 22, 2010 | 07:53 PM
rfgarvey37's Avatar
rfgarvey37
alright. thank you, and the truck is 4wd.
