bed swap
Old Feb 20, 2010 | 05:08 PM
paulq's Avatar
paulq
bed swap
Can someone please tell me what beds will work on a 1976 F250 highboy will any bed from 73-79 fit?
Thanks paul
Old Feb 20, 2010 | 05:18 PM
79fordf250pickup's Avatar
79fordf250pickup
Yes any bed from 73-79 will work.
Old Feb 20, 2010 | 05:34 PM
Vinford's Avatar
Vinford
Not every box will fit perfect.
Some frames are diffrent width.
Old Feb 20, 2010 | 06:18 PM
Blackfoot Big Block's Avatar
Blackfoot Big Block
Not so!
High-boy frames have a different frame width behind the cab than non High-boy trucks.
I believe any bed from a High-boy will fit (1973-1977.5). Any other 133" wheelbase bed will require modification.
Old Feb 20, 2010 | 10:54 PM
79fordf250pickup
I stand corrected.
Old Feb 21, 2010 | 10:51 AM
paulq's Avatar
paulq
I bought a 74 f250 2wd what mods have to happen to get the bed on also is the cab the same or will there be some mods that have to be done. The 1974 2wd is a reg cab 8ft bed.
Thanks Paul
Old Feb 21, 2010 | 11:39 AM
Blackfoot Big Block
My recollection (I did the bed swap a number of years ago) is the cabs will swap over just fine. To put a non High-boy bed on a High-boy frame, you will need to relocate one of the under-bed supporting crossmembers a few inches either forward or aft (don't remember) and you will have to drill new holes in the bed (and through the supporting crossmembers) for all the bolts as the High-boy frame is narrower.
It's not very difficult, or time consuming, but you should know what the swap entails.
Old Feb 26, 2010 | 08:42 PM
paulq's Avatar
paulq
Does anyone know what 2wd beds fit a highboy without mods?
Old Feb 26, 2010 | 08:47 PM
starmilt's Avatar
starmilt
Crew cab 2 wheel drive have the narrow frame up to 77.5 supposedly but my 78 still have it.
Old Mar 15, 2019 | 08:21 PM
Johnny L's Avatar
Johnny L
true. i got a hold of a shortbed off a 2wd crew cab (pre 77.5) and it was a direct bolt on to my highboy crew cab shortbed.
Old Mar 16, 2019 | 10:20 PM
grinnergetter's Avatar
grinnergetter
Putting a 73+2wd / 77+ on a highboy does not require moving a bed cm. You do however need to drill new holes in your frame, bed and sleeve the crossmember as your mounting holes will be located outward and a bit to the rear of the original holes. It's damn close but it fits. You will also need to mod the brackets at the rear of the bed as well....can't remember exactly what it was but it was pretty simple mod.
Worked for me anyway.
Old Mar 16, 2019 | 11:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/76 Stylesides have exposed fuel caps. 1977/79 Stylesides have fuel doors.
Old Mar 17, 2019 | 01:01 AM
Johnny L's Avatar
Johnny L
revival of a 9 year old thread! haha
i am busy scouring the forums for reference info as i am about to put a mint 78/79 shortbed on my highboy crewcab. will need to make the frame width adjustments for it to fit, but will be worth it!
here is the best thread i have found.
https://www.ford-trucks.com/forums/1...tion-help.html
jerryparks
Jun 16, 2014 06:44 PM
mcali2
May 21, 2014 11:38 AM
aracenjones
Jan 19, 2014 03:37 PM
jwtaylor
Nov 19, 2001 08:44 PM
