I have replaced multiple 175amp fuses and not just on superdutys (cougar, contour, mystic, expedition and many others) while I worked at Ford. After its replacement, it never came back for that charging issue.
I don't doubt that.
But tell me, on any of those vehicles you worked on, did you measure the voltage output of the alternator while the fuse was blown?
If you did, you would have found the alternator putting out it's rated voltage while running.
It'd be like a battery that isn't connected to anything. There is 12 volts sitting in that battery on the bench, but nothing is connected so the 12 volts doesn't go anywhere.
when check running or not being that it is in line the reading will be 0, if the fuse is blown it will show an difference (running 14.1, off 12.6 estimated). If the fuse isn't broken it will read 0 as its an complete circuit and if not then its an open circuit.
i found finally found it a wire was broken couple inches pasty the fusable links thanks for the help guys sorry to bother you guys but its done. i will be posting pics soon of the final product of my 4x4 conversion.
glad to see that its repaired, looking forward to pictures
