Aerostar Ford Aerostar
Starter Probs
Old Feb 19, 2010 | 11:53 PM
illenema's Avatar
illenema
Starter Probs
Went tot start up the 3.0 95 aerostar didnt turn over just did a "Click" at the solenoid switch on a cold engine Finally got it to start and it started 50+ times without a problem today, What needs to be changed??
Old Feb 20, 2010 | 12:56 AM
Bax2008's Avatar
Bax2008
Battery cables clean?
Old Feb 20, 2010 | 07:22 AM
Aeroman59's Avatar
Aeroman59
Probability .......75% corroded/loose connection somewhere, 25% starter circuit or motor. Battery/starter cables first!
Old Feb 20, 2010 | 09:38 AM
illenema's Avatar
illenema
Will check!!
Old Feb 20, 2010 | 09:43 PM
illenema's Avatar
illenema
Turned out to be the connection at the starter motor. Thanks!
Old Feb 21, 2010 | 02:35 PM
Aeroman59's Avatar
Aeroman59
Saved some bucks.
Well done , you probably saved yourself a few hundred right there!
I was just reading on a Mustang Forum the same deal. Someone had a similar starter problem , took to a garage, got charged for $200..... Which did not fix the problem. Turned out to be a corroded cable wire connection at the battery terminal! When I bought my Aero (1999) it also had an intermittent starting problem. I eventually traced it to the bolt connection at the starter relay, which was loose. Never forget to look for the obvious first.
Aeroman.
Old Feb 21, 2010 | 08:45 PM
illenema's Avatar
illenema
Yep. Thanks
freegdr
2004 - 2008 F150
17
Apr 13, 2011 08:25 AM
freegdr
Jan 29, 2011 06:11 AM
zippinz
1983 - 2012 Ranger & B-Series
Jul 28, 2002 02:45 PM
Ultramagdan
Jan 5, 2002 06:30 PM
