Sponsored by: Real Truck
Transmission problems
Old Feb 19, 2010 | 11:38 PM
Atwiss's Avatar
Atwiss
Ok so i am new to this site and just thought id tell you all that. but i have a 99 f250 and when i drive it the transmission pushes out fluid and runs on the exhaust and burns and when it just sits in one spot while running it will eventually shut off and suggestions or comments my friend said most likely torque converter and a seal would do the trick
Old Feb 20, 2010 | 06:21 AM
scraprat's Avatar
scraprat
Top Answer: 5
Are you sure it's the transmission leaking on the exhaust and not oil leaking out from the manifold cover (gasket) in the rear passenger side. It was a problem in that year of truck. My '99' 5.4 had the problem, you could smell oil burn smell occasionally.
Old Feb 20, 2010 | 10:56 AM
Atwiss's Avatar
Atwiss
thanks
im not sure i'll have to check that but do you know anything about the engine eventually killing itself just not sure on that part because we've had transmission problems before and now their saying its the torque converter
Old Feb 20, 2010 | 11:06 AM
scraprat's Avatar
scraprat
Top Answer: 5
I am assuming it's a gas engine. No, just check the oil level. I still have my '99' with over 240k miles and auto trans with nothing done to it. Who is they? Your transmission fluid is low? Why do "they" say it the tq converter... shifting hard or erratic? Throwing codes? I would think that if your losing trans. fluid it would be seen on the bottom of the trans. plus low on the stick or stains on the ground where your parked.
Old Feb 20, 2010 | 11:14 AM
scraprat's Avatar
scraprat
Top Answer: 5
When you say pushes out fluid do you mean at the filler tube? Have you changed the filter?
Old Feb 20, 2010 | 11:16 AM
Atwiss's Avatar
Atwiss
because after a while the engine locks up or shuts down and the parts store person told me the tq converter is just causing it to lock up thats the main problem im having with it
Old Feb 20, 2010 | 11:33 AM
scraprat's Avatar
scraprat
Top Answer: 5
I'm sure you have codes and need to find what they are. Not that I don't think "they'' know what "they" speak of, but I feel that there are more mechanics working behind counters that have done nothing more than dole out parts and repeating what "they" over hear. I could be wrong though.
Old Feb 20, 2010 | 11:39 AM
Atwiss's Avatar
Atwiss
thanks do you know how i would get those codes or just one of the code readers and will they find something like that
Old Feb 20, 2010 | 11:56 AM
scraprat's Avatar
scraprat
Top Answer: 5
Part stores like Advance auto can read them for free, it's as simple as hooking the reader to the connection below and to the right of the steering wheel beneath the dash.
Old Feb 20, 2010 | 10:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They can't read transmission codes. You need a tool with Ford specific software. Parts stores don't have those.
