Lincoln Continental... NEED HELP!
Old Feb 19, 2010 | 10:03 AM
nstueve's Avatar
nstueve
hey guy,
I have a 96 Lincoln Continental with a 4.6L V8. The engine doesn't shut off when the key is turned off and removed from the egnition. Owner says she has to unhook the battery cable and pull the fuse to the fuel pump before it will shut off... Any Ideas guys????
Old Feb 19, 2010 | 10:13 AM
darthice's Avatar
darthice
sounds to me like a bad ignition switch
quicklook2's Avatar
quicklook2
ignition actuator.
may have better luck by posting on a lincoln forum.
Old Feb 19, 2010 | 10:19 AM
nstueve's Avatar
nstueve
yeah i'll deffinatly post there I just didn't know if anyone would be able to give me an answer since i was already on here. A lady at work owns the car and wanted to know what the fix was for it... She already changed the ignition tumbler assembly. I will try a 4.6 v8 forum.
Old Feb 19, 2010 | 10:24 AM
quicklook2's Avatar
quicklook2
the ignition tumbler and the ignition actuator are 2 different things.
Old Feb 19, 2010 | 10:39 AM
nstueve's Avatar
nstueve
would the ignition actuator be like a igniton control module????
Old Feb 19, 2010 | 10:58 AM
quicklook2's Avatar
quicklook2
no, it acts like an ignition actuator.
Old Feb 19, 2010 | 11:13 AM
nstueve's Avatar
nstueve
ok... I was looking on RockAuto and trying to find the part that she needs to replace... Just so I'm understanding a ignition actuator is not a ignition control module and they are 2 seperate parts but both are in her car...
Or, they are 2 seperate parts but only one of which will be in her car?
Old Feb 19, 2010 | 11:25 AM
White 97 xlt's Avatar
White 97 xlt
ignition actuator or ignition switch, it's located on steering column near fire wall....
Old Feb 19, 2010 | 11:37 AM
quicklook2's Avatar
quicklook2
can you begin to see why this is not the forum to ask this on?
Old Feb 19, 2010 | 11:50 AM
Lazy K's Avatar
Lazy K
I am guessing it is similar to the truck system, in which case QL2 is right.
The actual ign switch would be on the steering column under the dash, connected back up the column to the key switch by a rod and the actuator.
The key switch turns a gear cog which engages the actuator and operates the rod to the ign switch.
You need to pull the steering wheel to get at it.
Old Feb 19, 2010 | 02:06 PM
subford's Avatar
subford
Ignition Switch
The ignition switch (11572), which is mounted on the steering actuator housing, operates in the following manner:
* The ignition switch is cycled through rotation of the ignition switch lock cylinder (11582) through a pin which is part of the ignition switch.
* The ignition switch lock cylinder also controls the mechanism which provides a positive lock for the automatic transmission linkage and steering system.
* The locking mechanism is located in the steering column housing.
The ignition switch lock cylinder positions are as follows:
ACC
LOCK
OFF
RUN
START
The ignition switch lock cylinder key can be removed from the ignition switch lock cylinder with the column-shift automatic transmission only when the shift lever is in PARK and the key is in LOCK position.
* The ACC position operates while the steering and automatic transmission systems remain locked.
* The engine shuts off when the key is turned to the OFF position without locking the steering or automatic transmission systems.
Blade Type
The ignition switch has blade-type terminals that engage with one multiple connector. The multiple connector is secured to the ignition switch by an integral connector fastener.
skipcox
Modular V8 (4.6L, 5.4L)
Feb 18, 2015 11:10 AM
bfletcher101
Modular V10 (6.8l)
Apr 24, 2012 08:08 AM
4inchlovin
24
Apr 24, 2008 05:51 PM
03Kodiak
Jun 19, 2007 06:54 AM
bryyce62
Nov 28, 2004 10:13 AM
