If your truck was made in late '94 or early 95 it will have a radiator cap on the radiator. If your truck has the radiator cap, make sure to get the right radiator, it will be listed as "early 95."
the hardest part is getting the fan clutch nut released. a long chisel and hammer is the easiest way to knock it loose. other then that there are no special tools required, just drain the fluid and remove the hoses and bolts.
