need some sugestions for an f1 radiator. The truck has a 351w engine with a c6 trans. I welcome any sugestions about venders and products that are available. Have not been able to find but one or two on line that provide to fit trucks that olds. not sure of their quility.
Here's a good catalog to brows through; U.S. Radiator Catalog
In it you will find good descriptions of radiators with core sizes, inleet/outlet tube sizes, bracketry, etc.
I chose the mid 70's Dodge truck radiator for my F1 (I'm running a 500ci Caddy). What I did was to search through the online catalogs until I found a radiator that I thought might work, then I hit the wrecking yards, friends, etc to find one in real life that I could measure and actually look at. Once I decided it would work for me I went over to my local parts house (Autozone, PepBoys, NAPA, O'Reileys, etc) and ordered one in. I think I paid $125 (its been a few years)
Another helpful bit of info for you: NAPA Auto stocks a complete line of radiator hose reducer bushings ranging in size from 3" down to 1 1/2". Here's the part #'s
NBH900 from 1.5" to 1.25"
NBH901 from 1.75" to 1.5"
NBH902 from 2" to 1.75"
NBH903 from 2.25" to 2"
NBH904 from 2.5" to 2.25"
NBH605 from 3" to 2.5"
I installed a radiator out of a 79 Ford Bronco. All I did was trim the sides of the flanges and I made my own mount using the old F-1 radiator mount as a templet. Check out my galley for piictures of the radiator and mount.
___________________________
46 Ford Tudor - Street Rod
48 F-1 - Dark as it gets
I looked at your gallery. Nice job on the radiator installation. My 302 has a driver's side water pump outlet. I looked up the 79 Bronco radiator and it has a passenger side bottom outlet. It's also wider at about 27.5 inches. The original 49 radiator was about 21 inches wide. Since I'm using the original radiator support I need something smaller (narrower) and with a bottom left outlet. Has anyone used a 55-57 T-Bird radiator? That looks like it might work in my case. What have you guys with a driver's side bottom outlet used? The Dodge truck radiator worked fine for my 48 but that has a bottom right outlet and I do not want to get into having the outlet moved...
