Mercury
Old Feb 24, 2010 | 09:26 AM
BarnieTrk's Avatar
BarnieTrk
What is the MODEL code of this truck? The seller didn't post a pic of the Warranty Plate, which raises a Red flag.
Yes, the seller did post the Warranty Data Plate.
It's at the end of the "slide rule" of pictures.....
F10YC860616
wheelbase: 129
color: WM
model: F100
Body: B81
Trans: A
Axle: 17
GRWR: 05000
Net HP: 172
RPM: 4000
DSO: A7
In the upper RH corner of the plate it says: Made in Canada
BarnieTrk
Old Feb 24, 2010 | 03:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10YC860616
wheelbase: 129
color: WM
model: F100
Body: B81
Trans: A
Axle: 17
GRWR: 05000
Net HP: 172
RPM: 4000
DSO: A7
BarnieTrk
I looked at every picture in this ad when the OP first posted the info, there was no Warranty Plate pic...and I still don't see one.
Is the above Warranty Plate info correct for this pictured Mercury M100...or not? Something smells, and it ain't hay.
I have the 1966 Ford factory color chip chart. WM: W = Marlin BLUE (Medium Blue) / M = Wimbledon White.
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
If the truck was Blue and White originally, why did the seller repaint it Caribbean Turquoise (COLOR code B) and White?
MODEL F100 = F100 2WD / 5,000 lbs. GVWR.
Old Feb 24, 2010 | 04:14 PM
IsoGrifo's Avatar
IsoGrifo
it definitely says ford made in canada.
Also, if you look at the upper valance where the e, c, & r are, is that how mercury attached those letters? just welded on some extra plates? or is that someone's install job?
Old Feb 24, 2010 | 04:18 PM
Zip's Avatar
Zip
Looks the same as mine.
Old Feb 24, 2010 | 04:28 PM
NumberDummy
Also, if you look at the upper valance (grille panel) where the e, c, & r are, is that how mercury attached those letters? just welded on some extra plates? or is that someone's install job?
Both Ford and Mercury trucks were assembled and sold new in Canada. Ford also assembled Ford trucks in Canada and sold them in the US of A...and still does today.
Since the MODEL code is F100, the assembly plant code is C and the DSO code is A7, this truck was assembled in Oakville, Ontario Canada, and sold new in the Pacific District of Canada.
C5TZ8190C .. Upper Grille Panel / Fits: 1965/66 FORD F100/700.
CC6TB8190B .. Upper Grille Panel / Fits: 1966 MERCURY M100/700.
Where or where are the specific to MERCURY only front fender emblems? No see um.
Old Feb 24, 2010 | 04:33 PM
IsoGrifo's Avatar
IsoGrifo
also in question of the seat, it isn't even an original seat, you can tell by where the slider release is.
Old Feb 24, 2010 | 04:38 PM
masterqi's Avatar
masterqi
Old Feb 24, 2010 | 04:40 PM
Zip's Avatar
Zip
Exactly the same as mine.
Old Feb 24, 2010 | 04:45 PM
IsoGrifo's Avatar
IsoGrifo
Because Caribbean Turquoise is a prettier color! I mean, why does anyone repaint their vehicle a different color, especially when trying to sell, they pick one that will sell, and you will always have a high demand for rangoon red (Wasn't there a different red too?), caribbean turquoise, and black on these trucks.
Also notice it has all of the custom cab goodies, the sweep speedo, the (incorrectly chromed, but...) shiny grill, windshield reveal molding, but NO custom cab door script! is it a custom cab clone as well? something tells me the script wouldn't fit on after those wrong mirrors were put on.
Old Feb 24, 2010 | 04:46 PM
IsoGrifo's Avatar
IsoGrifo
maybe ZIP's is a clone too! haha
Straight from the seller:
Q: Is it have ford or mercury on the paperwork? Thanks,jeff
A: The title shows Mercury.
So whether it originally was a ford or mercury, it doesn't matter because it is officially a mercury now! I'm starting to believe that it is possible that it truly is a merc, and those badges were in bad shape, or were broken, or lost in the restoration process, and you see restored Fords that don't have the badges too! so... who knows... whether it is or it isn't, it's still a nice looking truck.
Old Feb 24, 2010 | 04:56 PM
NumberDummy
This is your opinion, others may not share it.
By the BODY code, it is a Custom Cab.
If the Custom Cab door guards were on this truck originally, it would not have Custom Cab door nameplates.
If the Custom Cab door guards were factory installed...Ford...for some reason did not install the side mouldings.
Parts catalog sez: C3TZ8120966A right & C3TZ8120967A left = Use without side mouldings.
btw: I could type a history of the color green...but..I'd rather not.
Suffice to say that green was not available for certain years, as it had gone out of favor.
Old Feb 24, 2010 | 04:57 PM
Zip's Avatar
Zip
my lettering
Name:  003 - Copy.jpg
Old Feb 24, 2010 | 04:59 PM
  #28
IsoGrifo's Avatar
IsoGrifo
but it has the side mouldings and the regular style door handles!
blackhawksfan77
Jan 13, 2020 09:47 PM
fifty-two_f1
WTB - Parts & other
Dec 27, 2015 10:23 PM
Mr Mercury
1947 and Older Ford Trucks
Feb 15, 2014 10:39 AM
66slick
35
Mar 4, 2008 03:52 AM
Mr Mercury
Sep 25, 2003 07:34 AM
