New improved carbon fiber heater boot mold for the '52 version .Also am close to finalizing the process to make e-brake cable boots . Will keep all informed .
Heater boot mold with inside buck .
SEE PICTURES IN FOLLOWING POST .Thanks to a late night tutorial from picture posting guru Ilya have once again found the correct path to posting pics .Ilya ,thanks again,Denny
Other half of mold w/ inside buck .
I hope pics loaded or Ilya will disappointed !
Reason: Will try agin fri .Darn !!
Ilya , thanks . .Did you obtain the pics from my gallery then post ? Tried that 308 # you gave me in the e-mail but message said # has been disconnected or no longer in service .Still need a tutorial on posting pics . Followed your instructions but must be missing a simple step .Thanks again , Denny
Round end boot for '51
The results of correctly measuring the 2 part liquid rubber to the gram .Work time is around 8 minutes then it start to move real slow .This is the same process that will be used to make the e-brake cable boots .Have 8 of each style heater boot in stock .
