HELP!! 1994 F250 International Non-Turbo Diesel Just Dumped LOTS of Oil
I have a 1994 F250 with the International non-Turbo diesel engine.
I haven't started it for about a month and I did so today and got an unpleasant surprise.
When I started it, it started dumping oil somewhere from the lower front of the engine somewhere forward of the oil filter (not the oil filter) and below the power steering pump on the driver side of the engine.
I can't see where the oil is coming from but there is a LOT of it.
As you'd expect, the oil pressure gauge is at zero.
Anyone have any ideas as to what might have just happened?
Is there a seal or something in that area that could have let go, or what?
Any help will be greatly appreciated. I'll try to crawl under it tomorrow and see if I can get into a position where I can see where the oil coming from.
Again, thanks in advance for any of your ideas!!
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums Here is a link to the page for your engine. Probably get more response if you post your problem there.
Good luck.
Good luck.
Good luck.
Good luck.
Thanks Lazy K, I didn't see that forum category. I've re-posted it there.
Cheers!
OIL COOLER
Good Luck
bigbellyking
10-17-2015 01:40 AM
pikie1901
12-19-2014 01:44 AM
oct7brian
34
01-08-2012 03:40 PM
JoeVR5
07-04-2008 07:47 AM
Diesel-N-Bucket
12-20-2003 08:30 AM
