Sponsored by: Real Truck
need help with upfitters
Old Feb 18, 2010 | 02:45 PM
in heat's Avatar
in heat
I am trying to find the plug for the upfitter relays< I am instaalling upfitters on an 08 with out the switchesa and I bought the kit ,. I have the tech pics and instructions from ford but I for the life of me can find the plug for the harness?
Old Feb 18, 2010 | 02:52 PM
Jigger2020's Avatar
Jigger2020
when you look behind & above the glove box on the passenger side there should be an auxiliary fuse/breaker box up there .if it is not there then you don't have the wiring harness for upfitter swithes,goodluck, Gigger
Old Feb 18, 2010 | 03:04 PM
rjfetz1's Avatar
rjfetz1
I had mine done before I took delivery at the dealer....i was going to do it myself however they said I needed a complete wire harness that came in a seperate box and it was a 1 1/2 hr job. Not sure if you have the complete harness or not. Hope that helps somewhat.
Old Feb 18, 2010 | 04:05 PM
in heat's Avatar
in heat
I found the plug it was buried! factory fogs all hooked up and working!!! the upfitter switches are the *****!! I zip tied the relay box to the opening of the panel below the steering wheel for easy acces to the thee other wires that I now have to buy some thing to hook up to them.
Old Feb 28, 2010 | 04:25 PM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
HELP! Please give me a better description than "It was buried"? I just spent two hours outside in the cold digging, twisting my body into shapes that a 60 year old shouldn't be able to and couldn't find that F'n PLUG! I even used a 6"X8" mirror and lots of light - still NO GO! Any better description would be a great help!!! Thanks in advance...
Old Feb 28, 2010 | 04:30 PM
in heat's Avatar
in heat
its a bitch to get to but if you stick your head up against the gas pedal and look straight up you can just see a grey plug it has a dust cap in it but it is almost over the radio in that area its there on all sd trucks you are going to sratch hech out of your hand beacause you can only get one hand to it, I would give you a hand with it if you lived close to maine.
Old Feb 28, 2010 | 04:31 PM
in heat's Avatar
in heat
its up pretty high, its light grey in color you can oly see a little bit of it.
Old Feb 28, 2010 | 05:07 PM
jimd1050's Avatar
jimd1050
Aarrggghhhhh!
Thank you... I'll give it another shot on a warmer day! It's funny - everything else, I located - the holes to bolt the relay box to, the hole for the ground wire, the feed through wires, etc. Other than that damned plug to tie the whole thing in, I'd have it made!
Thanks again for the reply!
Old Feb 28, 2010 | 05:10 PM
in heat's Avatar
in heat
its there dont give up I was two hours locating it but I found it its up pretty high
Old Feb 28, 2010 | 07:54 PM
bayou barataria's Avatar
bayou barataria
On my '08 it was strait up from the steering column, just shine a flashlight up there it is close to the top. I tried to put the relays where they said but it was impossible to get the screws to line up so I just zip tied it up there.
Old Feb 28, 2010 | 08:04 PM
jimd1050's Avatar
jimd1050
Thanks everyone - I'll give it another shot when it warms up a bit - right now, snow on the way again! Come on SPRING!
Jhndere
Dec 22, 2016 11:42 AM
Bigdon68
Sep 14, 2016 08:52 AM
Necronommicon
Electrical Systems/Wiring
Mar 12, 2016 06:52 AM
TFLT
Jan 8, 2016 02:18 PM
ligito
Apr 6, 2015 03:01 PM
