Gage probe installation questions
Old Feb 18, 2010 | 09:51 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
I am getting a set of gages. Trans temp, boost, and EGT. Where do the probes need to be installed? Pictures would be perfect.
Thanks!!!!
Old Feb 18, 2010 | 03:05 PM
Zmann's Avatar
Zmann
DieselManor - Installation Sheets
Old Feb 18, 2010 | 03:18 PM
02GrayPowerStroke
Originally Posted by Zmann
Great link, reps to you.
Old Feb 18, 2010 | 04:13 PM
Zmann's Avatar
Zmann
Thanks ,, Have fun!!
Old Feb 18, 2010 | 05:08 PM
Subsailor1127's Avatar
Subsailor1127
02Gray, hopefully you will not be as nervous as I was about drilling into the exhaust manifold just below the turbo uptake pipe. I followed several peoples advice about leaving the bits dry instead of putting grease on them (used the graduated bit method after drilling the pilot hole to keep the shavings small and also not have to push so hard and get shavings on the "wrong side" of the hole). I vacuumed out the hole as best I could after I tapped it. Mine came out fine and good luck to you. -Glenn
Old Feb 18, 2010 | 05:14 PM
utjer's Avatar
utjer
I just did this last saturday also. Same procedure, kept the bits dry so the flutes wont clog up and vacuumed it real well to make sure I got all the shavings. I was pretty easy. There was actually enough room in there for my cordless drill which was nice.
