06 PSD Cold Start Question
Old Feb 21, 2010 | 11:38 PM
maxum96's Avatar
maxum96
Mine spins over fast no matter if it's hot or cold. Hot, it fires off instantly.
Old Feb 22, 2010 | 05:39 AM
bismic's Avatar
bismic
As the TSB states, 2-3 seconds isn't terrible. If you are determined to improve it, check FICM voltage (as previously suggested). Then, the 5W40 oil (yes even though you just changed the oil, 5W40 really does help) and the update to the most recent heat flash would be next. This assumes that you do not have a weak NEW battery. 15W40 WILL put more load on a cold startup. Again - as previously stated, new batteries aren't always perfect.
Glow plugs are very reliable as a general rule, but a search on this site will show you how to test them and change them if that is really what you want to try.
Old Feb 22, 2010 | 07:00 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Load test your batteries and eliminate them as a problem.
Good luck......
