Offroad & 4x4
axle questions
Old Feb 18, 2010 | 06:55 AM
alpha/omega's Avatar
alpha/omega
no, I dont think you are annoying. Prozon is annoying, and Id never place you in the same catagory as him.
Old Feb 18, 2010 | 12:05 PM
79Ford4x4's Avatar
79Ford4x4
Don't be sorry for asking questions. That's the only way you'll learn without wasting a bunch of money with the trial and error thing
Old Feb 18, 2010 | 02:33 PM
going up 2!'s Avatar
going up 2!
yes,u can just buy the outers,remove the u joints from shafts and install new u joints if u buy the new outers.if u go w/ 35 spline outers u will need to buy new front lockouts.if u have axle all apart i would take the time and money and replace all seals and bearings.try 4wheeldrivefactory.com,they have a complete front 60 rebuild kit.every bearing,race,seal,u joints,king pin ect....
Old Feb 18, 2010 | 07:44 PM
dillinewton's Avatar
dillinewton
ok quick question, how do i know if my dana 60 ring and pinion is reverse, or standard thanks, ok this is what i got so far.front complete rebuild kit, front true trac locker, 5.13 gear, snofighter 35 spile chromo axle shafts(these will be 1.5" all the way right, no neckdowns),rear locker and and 5.13s. what do you guys think about that so far? already breakin the bank but o well
Old Feb 18, 2010 | 08:04 PM
going up 2!
if its a high pinion axle then its reverse rotation,low pinion is standard.depending on year,most ford 60's are high pinion.
Old Feb 18, 2010 | 08:31 PM
79Ford4x4's Avatar
79Ford4x4
Looking to spend some money there ain't ya
Old Feb 18, 2010 | 08:45 PM
dillinewton
hahaha ya man, too much, but i wanna have the baddest truck around so i guess i will have to work so much im not gonna be able to work on it until next year haha
Old Feb 18, 2010 | 11:34 PM
mark a.'s Avatar
mark a.
No such thing as "reverse rotation" high pinion or low pinion, both turn the same way. The high pinion has a reverse cut ring & pinion.
Old Feb 18, 2010 | 11:42 PM
mark a.'s Avatar
mark a.
Who told you to buy a Truetrac ? Man is that a MEGA turd, a REAL sorry excuse for a locker. Cancel that order & get a Powr-Loc.
Old Feb 19, 2010 | 06:33 AM
dillinewton
well i was going to get that for the front, because i wanna drive this badboy on the road, without hearing weird noises, or hopping around corners. its better no sort of locker up front right?
Old Feb 19, 2010 | 07:24 AM
mark a.'s Avatar
mark a.
I wouldn't put one in anything they are junk, period. A Powr-Loc is the only way to go unless You want to try a Detroit which can be a little hard on things. The Powr-Loc has great manners and will last a good long time. I have them in my front and rear, turns fine. I have never felt anything in the steering & it turns both of them all the time far as I can tell.
Old Feb 19, 2010 | 07:43 AM
alpha/omega
That was probably me.
Ive never used either......just picking one out of CORs website.
Old Feb 19, 2010 | 10:11 AM
  #28
dillinewton
so is the power loc a fully locked or is it limited slip? thanks
Old Feb 19, 2010 | 11:57 AM
  #29
going up 2!
i didnt mean high pinion was reverse rotation as thats how it spins,i thought when u order ring&pinion it was classified as reverse rotation?i may b wrong,i got my gears free of charge...
Old Feb 19, 2010 | 12:00 PM
  #30
going up 2!
The Power-Loc is similar to the Trac-Loc, but is a more heavy-duty unit. Like the Trac-Loc, it is a clutch-type limited slip. It uses floating cross shafts that ride on a ramp in the differential case. When power is applied, the shafts ride up the ramp and load the clutches for a more positive engagement. While it doesn't lock up 100 percent, it is a very aggressive and durable limited slip. Power-Loc units feature a two-piece case and four side gears. This unit can be rebuilt, and by stacking the clutches differently, you can vary the slip percentage to make it more effective on the trail or less harsh on the street
