2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
How to Reprogram Keyless Entry???
Old 02-02-2010, 12:37 PM
R-WEST's Avatar
R-WEST
R-WEST is offline
Got a nice pre-owned '09 Nav over the weekend. It has the keyless entry system, but, I don't know what the entry code is, and I can't find the little tag in the Owner's Manual that had the factory setting. How do I change the code?
Old 02-02-2010, 01:02 PM
function12's Avatar
function12
function12 is offline
Need to have the original code to add/change code. I believe you will have to go to the dealer to get them to pull the code.
Old 02-02-2010, 01:54 PM
berry1234's Avatar
berry1234
berry1234 is offline
Yes, dealer has to pull the code from the computer. Without the master code, you can't add your codes. I would call them and make them pull the code.
Old 02-02-2010, 03:39 PM
R-WEST's Avatar
R-WEST
R-WEST is offline
Thanks, much!! To the dealer I go...
Old 02-02-2010, 05:22 PM
merlynr's Avatar
merlynr
merlynr is offline
Just had that done on a used Edge. Had to visit the dealer. No charge, but I bought it there.
Old 02-02-2010, 09:12 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I know their used to be a sticker in older FoMoCo products with the code on it. It was under the trunklid on my SHO's. I'd think if Ford still did that somebody would have told you where to find it, but you might poke around in the cargo area anyhow. For security purposes, the code would likley be someplace you could lock.
Old 02-03-2010, 11:18 AM
berry1234's Avatar
berry1234
They got rid of that in the 07 and up models. Have to have it pulled by the dealer.
Each vehicle equipped with a keyless entry keypad is programmed with a 5-digit entry code. This code is provided to the customer on a wallet card in the Owner's Literature package. In addition, this code is available through a scan tool.
Old 02-03-2010, 12:06 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
according to my Repair Manual DVD, the code is still printed on the SJB...which is in the drivers kick panel on the 07+ Expy.
look for a little PCM looking thing. if it's there, there will be a white sticker with a 5 digit code.
if not, then yeah...gotta pay the Dealership
Old 02-03-2010, 12:11 PM
berry1234's Avatar
berry1234
I am gonna check this out.
Hmm. It gets more interesting. Saw this on another forum.
You should find the keypad code on the back of the (SJB) Smart Junction Box located behind the front passenger kick panel. Remove the panel and remove two bolts holding the SJB, once you do that you should be able to read the number (small print) on a white sticker, look for a 5 digit numerical code.
Crap, I didn't bring my tools to work.
Old 02-03-2010, 04:29 PM
R-WEST's Avatar
R-WEST
R-WEST is offline
Holy mackerel berry - don't tear yours apart!!
I'm going to the dealer to get a remote starter installed anyway!!
Old 02-16-2010, 05:56 PM
benshere's Avatar
benshere
benshere is offline
There is extensive information on the "Supercoupe" sites on the keyless entry modules and how they work. Probably on the SHO sites as well, just have to search.
I have saved and printed the info for the supercoupes----BTW, anyone want to buy a 92 with the usual blown head gasket issue?
The keypad wires to a control module that has 5 resistors on a PWD board. it is the placement of the resistors on this board that determines the sequence of the buttons. Anyone with some wiring skills can rearrange the resistors for their own pattern. If all else fails, the pattern can be determined by looking at the resistors on the board.
I am not sure that the new vehicles use the same method, it may be in software on the DT control module now----dont know.
Maybe someone with alldata can looksee if there is any info shown on the modules specs.
Old 02-16-2010, 10:54 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
it is all programming now benshere...it seems to run about $50 for the Dealership to connect to the PCM and talk via the CanBus network...annoying, but technology is pretty cool
Old 02-16-2010, 11:24 PM
benshere's Avatar
benshere
benshere is offline
Its been a while since I did anything to do with programing or processors. The longer I am out, the further behind I get "Technologically displaced". I cant help but wonder if that bus can be accessed by some enterprising car nut. I can guess that its the location or access for all the "snooping" info that is gathered, such as data logged for the previous seconds or minutes of driving. You know, all the hype about lojack on new cars. Sounds good, but just wait until it gets used against you.
Might be useful to have a shorting pin to use similar to resetting the bios on a motherboard when you dont want your last few minutes of history to be seen!
Isnt it amazing how people can hack PC's and steal you blind, but dont seem to be able to hack a car system. and its not even a terribly sophisticated system---just proprietary. Oh well! guess I am in a paranoid phase----.02!
crozz
Iowa Chapter
03-07-2017 12:23 PM
fordor
2004 - 2008 F150
19
02-17-2017 02:54 AM
61 uni
12-30-2008 08:11 AM
3KIDDAD
01-17-2007 09:13 PM
otismojo
04-29-2002 03:03 PM
Quick Reply: How to Reprogram Keyless Entry???
