Pulling Engine
Old Feb 17, 2010 | 07:13 AM
Happy-Hoppie's Avatar
Happy-Hoppie
Pulling Engine
Getting ready to pull my 6.0 out I just need to know, How much does the complete engine weigh. I am told that my old gasoline engine lift is too small. Also any things to watch out for while I am doing this job (surprises)<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"> <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape style="WIDTH: 11.25pt; HEIGHT: 11.25pt; VISIBILITY: visible; mso-wrap-style: square" id=Picture_x0020_1 alt="0" type="#_x0000_t75" o:spid="_x0000_i1025"><v:imagedata o:title="0" src="file:///C:\DOCUME~1\LEONAR~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_image001.gif"></v:imagedata></v:shape>. The engines I am use too pulling are Cumming VT 903 and we have a crane for that. (boat engine)
Old Feb 17, 2010 | 08:38 AM
rickatic's Avatar
rickatic
Happy...
I just did this and finished on Sunday. We pulled the engine and transmission together out the front. We removed the entire front grill section, the front core support, all the coolers, moved the a/c condenser to the side, and pulled the fan and shroud. We then disconnected all the fuel lines and the engine wiring harness. We removed the turbo and disconnected the exhaust. I have a MBRP exhaust system so we removed the down pipe for more clearance. We then hooked the engine up to a 2 ton overhead chain fall and picked it up. We installed a 3/8 grab hook into the passenger side head with a grade 8 bolt to allow us three places to hook up the chains. The other two lift points were the drivers side factory lift ring and through the turbo pedestal. This hookup allows the removal of the engine without damaging the rim area of the upper firewall. If you try to use to rear lift ring it will tear up that rim. I know because we tried it. As we raised the engine up we rolled the truck backwards. My oil pan was too close for comfort so we removed it and the oil pick up. After all this, the engine slid right out the front. We connected a HD nylon tow strap from the chain fall hook to the rear of the transmission for balance help and set the entire assembly on a old tire on the the floor. I have a 1 ton engine hoist that we sort of used to move the assembly to the heated part of the garage. It was really not enough. The engine/trans/ transfer case assembly is HEAVY.
Good Luck
Old Feb 17, 2010 | 10:04 AM
teppler's Avatar
teppler
Why are you pulling engine? Good info keep us informed. Pictures would be great also.
Old Feb 17, 2010 | 10:39 AM
cartmanea's Avatar
cartmanea
They are around 1100 lbs, don't use anything rated under 1 ton for safety.
Old Feb 17, 2010 | 06:15 PM
Happy-Hoppie
Thank you for all your input, I didn,t think my lift would suport it. I am not sure of it's capacity but it is old so I will buy a 2000# one and sell the one I got. I really don't wana say why I am pulling it because I did somthing stupid and I now need to check the main barings. I am hopping to change out the head bolts when I do get it pulled also.. This might be all for nothing as I might be getting forced to retire which will mean no money ( also no truck).. we wiill see though...But once again thank you all
Old Feb 17, 2010 | 06:53 PM
rickatic's Avatar
rickatic
Happy...
I would go bigger with the hoist. My 1 ton would barely pick it up and I had to ride the back of it while we moved it. I would not try to raise the motor out of the truck with it. How are you removing the engine, out the front?
Old Feb 18, 2010 | 12:16 AM
cartmanea's Avatar
cartmanea
You can't leave us hanging... What happened? Start it in the middle of an oil change?
Want-A-Be 7.3
Nov 18, 2009 06:40 PM
2 fowl
Mar 20, 2008 11:26 PM
AK Fifty-Three
18
Sep 17, 2006 11:20 AM
AK Fifty-Three
18
Mar 27, 2006 08:25 PM
threetago
2004 - 2008 F150
15
May 26, 2004 04:26 PM
