Sponsored by: Auxito
Vibration AT 65mph
Old Feb 16, 2010 | 11:30 PM
zamunda's Avatar
zamunda
Vibration AT 65mph
Hi everybody. Well I've got a vibration...more heard than felt. I can't really tell if its coming from the front or the back. It starts around 63 mph and is really noticable at 65 then starts to go away around 70. Its kind of rumbling sort of sound. I thought maybe shocks, replaced the fronts and no change. They were shot... so I'll be changing the rears this weekend. I just put new tires on (bf goodrich long trail) and had an alignment done too. I don't think it was doing this before the tires and alignment. Tires were first (at samsclub) and then alignment (brakemasters) , but I don't recall it happening right after either place. I'm thinking maybe I might have lost a weight on one of the tires... I think that happened to me before. What do you guys think? I do have to drive over rumble plates at work, maybe that shook one loose... any ideas greatly appreciated.
Old Feb 17, 2010 | 08:21 AM
fordtech08's Avatar
fordtech08
that could be the case also take a close look at your drive shaft look for dents also take it out and move the u-joints see if there is any binding or they are loose
Old Feb 17, 2010 | 08:30 AM
fordtech08's Avatar
fordtech08
run your hand along the tread of the tires from front to back feel if the tire has ridges, after that run your hand ack to front, if it's feathered ( rough one way smooth the other) that could make the noise just put the tire to the other side so the smooth side faces forward, that will reduce the noise
Old Feb 17, 2010 | 10:39 AM
sidearm11's Avatar
sidearm11
most likely lost a wieght(get it rebalanced) or ur u joints are shot. disconnect rear yolk from dif and see if its seized up.
Old Feb 17, 2010 | 10:06 PM
zamunda's Avatar
zamunda
Thanks alot for the replys... Took it back to samsclub today and had the tires rebalanced. They said only one was very slightly off. The tire guy at SAMS did say that there is some play in my front passenger wheel bearing... that makes sense doesn't it? I know they can squeal and I think I've heard that they can kind of rumble... I won't have a chance to check it until the weekend... can you tell me how to check it, myself? I looked at autozone and the bearing is only lik 12 bucks... I just hope it isn't a pain to install. Let me know if this sounds reasonable... and any advice you have... I'll check the u joints at the weekend too. Thanks again. Oh an no feathering on the tires...
Old Feb 18, 2010 | 11:50 AM
tooNz213's Avatar
tooNz213
wish i could help
Old Feb 18, 2010 | 01:26 PM
IndySilverAnny's Avatar
IndySilverAnny
Did you drive it up to speed after they rebalanced the tires? I've got a light rumble also, only noticeable after Midas replaced the U-Joints. They tried 3 sets thinking they got a bad set, and it's still there. They think either the front input bearing is going out, or the rear gears are worn, and the tight u-joints now allow the vibration to make it up into the floorboards. Kinda makes sense to me. I hadn't thought about the wheel weights though. I need to have them checked. Maybe one got knocked off.
Old Aug 21, 2023 | 12:12 PM
Tom vess's Avatar
Tom vess
1st Gear
Vibration at 65 mph
Old Aug 23, 2023 | 07:25 AM
Airborne 82nd's Avatar
Airborne 82nd
Angry
What year? Two wheel drive?
You could just retorque the spindle nut to see if it changes. You can not just tighten it up If the sound does change then think about changing bearings before you spin a bearing. Don't put it off or you might lose a rotor or spindle don't ask me how I know. It is not a hard job but has to be done right.
Airborne
battmanf16
22
Mar 11, 2020 11:36 PM
McStein
1983 - 2012 Ranger & B-Series
Jan 11, 2017 11:31 AM
chipper
Jun 5, 2016 11:01 AM
F350-6
May 15, 2016 08:37 PM
bobrpm306
1997 - 2003 F150
Jan 5, 2012 08:38 PM
