Engine #'s for ID?
Old Feb 16, 2010 | 09:18 PM
sammycooks's Avatar
sammycooks
Engine #'s for ID?
These are numbers from a rebuild that I'm considering adding to my garage... can anyone give me some additional info based on these?
Thanks
BLOCK: D4TE
HEADS: D2TEAA AND 203
INTAKE: 7A19 AND CTTE9425-F
Old Feb 16, 2010 | 09:27 PM
garbz2's Avatar
garbz2
Built in 74 or after. Part numbers are basically Usless to determine size.
Depending on the engine family that part number can be used almost the entire run.
Garbz
Old Feb 16, 2010 | 09:35 PM
sammycooks's Avatar
sammycooks
I see. I'm told it's a 360, but haven't had an opportunity to inspect it physically. It supposedly came out of a 66, although the seller doesn't claim it to be the original engine. How did you arrive at 74+ ?
Old Feb 16, 2010 | 10:08 PM
garbz2's Avatar
garbz2
The D is for the decade 1970. C is for the 60's
The 4 is the year in the decade the rest is the engineering code (engine Block) and revision. So it has to be 74 or later based on this part number.
If it is a FE this will be a reverse 105 or mirror Block and good for a rebuild into a 390 or 410.
The heads are 72 consistent with a 74 FE they will have hardened seats for the valves for unleaded gas.
If the engine is genuine to the truck it would be a C5ME Prefix.
Garbz
Old Feb 17, 2010 | 02:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
BLOCK: D4TE
D4TE = 1974/76 360/390 bare block casting number prefix.
D2TE-AA = 1972/76 360/390 cylinder head casting number.
7A19 = Intake manifold cast January (A) 19, 1967 (7).
It's C7TE (not CTTE) 9425-F intake manifold casting number.
bismic
Feb 22, 2024 09:29 PM
NoFrod
Large Truck
Oct 12, 2016 03:58 PM
toymobile
Ford Truck Parts for Sale
Oct 2, 2016 03:01 PM
benbuilder
Jul 14, 2015 05:06 AM
keisha9
Jun 7, 2007 09:38 AM
