what would you get....
Old Feb 16, 2010 | 07:45 PM
formula joe's Avatar
formula joe
If you could only get one, RAS or rear sway bar? Reason would be to improve towing. I'm leaning towards RAS, what would you do?
Old Feb 16, 2010 | 09:26 PM
USMC616's Avatar
USMC616
I would lean towards the RAS since it does help control axle wrap.
Old Feb 17, 2010 | 07:52 AM
soutthpaw's Avatar
soutthpaw
if you don't have a rear sway bar at all then I would get the sway bar. it helps control trailer sway under all conditions axle wrap is only present under accel or hard braking.
Old Feb 17, 2010 | 08:09 AM
gr8scott72's Avatar
gr8scott72
I would get the RAS and did. Great towing improvement!!
Old Feb 18, 2010 | 08:11 PM
formula joe
as far as the rear sway bar, I don't have one. My question is would the hellwig be that much better than the ford stock one?
