Sponsored by: Real Truck
what the hell??
Old Feb 16, 2010 | 07:14 PM
jsparrow's Avatar
jsparrow
what the hell??
So this is probably the eleventh or twelvth post I've put up on this issue. My truck shuttering to **** when I stop. I've replaced the pads rotors shocks ball joints blah blah blah...but today I noticed something odd.... in my front drivers side leaf spring perch one of the u-bolt holes is ovalized. Would it cause that crazy shuttering if it was just one of them? Also I noticed recently that the effect is more due to weight transfer than actual braking. If I put it in reverse and give it some gas....the front end clinks when the truck starts moving. If I do have to get the perch(es) replaced...that involves cutting and welding right? Has anyone had this done? How much did you pay?
Old Feb 16, 2010 | 07:36 PM
Lou Braun's Avatar
Lou Braun
Your front leaf springs are held in position by a pin on the bottom of the spring pack. This pin indexes into a hole in the spring mount.
As long as the pin is still there and the u-bolts are properly torqued, the holes in the spring plate don't really do that much. Loose U-bolts will cause the axle to shift and make a clunking sound.
I'd make sure that the spring pack pin (it is actually a bolt that goes through the entire spring pack) is in place and that the u-bolts are properly torqued. Fix the easy stuff first.
Lou Braun
Old Feb 18, 2010 | 11:16 PM
razky's Avatar
razky
Originally Posted by Lou Braun
. . .u-bolts are properly torqued. Fix the easy stuff first.
Lou Braun
do you (or anyone else) happen to know what the torque settings are for the u-bolts?
Old Feb 19, 2010 | 12:25 AM
Steve the fireman's Avatar
Steve the fireman
as far as I know there really is no torque specs to u bolts. Ive done a few lifts and every lift that i have done all you do is get them as tight as you can. just tighten them up drive it for about 50 to a 100 miles and recheck them. after that i use to check mine when i filled up.
Old Feb 19, 2010 | 02:20 AM
Zip's Avatar
Zip
Front - 99 lbs
Rear - 185 lbs
As per Haynes manual 1999 - 2002.
Old Feb 19, 2010 | 05:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a torque spec for every nut, bolt, and screw on the truck.
