trailer brakes locking up
Old Jan 19, 2003 | 09:13 PM
ford_nut's Avatar
ford_nut
Guys
what would cause my trailer brakes to lock up? On the electronic controller in the cab, the sensitivity and voltage controls are set exactly 1/2way, I backed them DOWN some but I still hear the brakes lock coming to a swift stop. SHould I continue to back the controls down some more? FYI, i have the drawtite Activator controller. Anyone have ideas? Thanks
regards
Ben
Old Jan 20, 2003 | 11:05 AM
jim henderson's Avatar
jim henderson
Could be lots of things, but usually it is an improperly adjusted controller.
Don't know the model and stype you have, but in general they need to be leveled(this affects everything else) and then the gain and I think timing need to be adjusted.
Best bet is to look at the manual. Mine is a Tekonsha, forget model but the two **** settings are fairly low. Note that the settings will change with road conditions. I like to set mine to where the brakes just barely lockup on a hard stop on dry pavement, but this changes in rain etc.
Good Luck,
Jim Henderson
Old Jan 20, 2003 | 11:58 AM
penguin149's Avatar
penguin149
Thumbs up trailer brakes locking up
I use a Tekonsha Prodigy with my travel trailer and it beat the Kelsey/Hayes controller I had hands down! With the Prodigy, set it up one time and no other adjustments are needed. It senses how quickly the truck is stopping and applies the appropriate amount of trailer brakes. No more adjusting for city/highway and wet/dry! After stopping, the amount of current running to the brakes is reduced to 25% to prevent overheating, etc.
Well worth the $120 or so.
Jim
Old Jan 21, 2003 | 11:29 AM
motobub's Avatar
motobub
I have the same brake contoller in my Power strokes. Mine are for 3 axle tailers. Get in gravle and set the brakes on 0. Then drive in the gravle and step on the brakes untill they lock up, then just back it off a little.
Lars
GGWild
13
Jul 28, 2013 05:23 PM
jmcbrid
6.4L Power Stroke Diesel
Nov 16, 2011 09:12 AM
dan8052
All Things Towing
Jul 28, 2010 04:06 PM
Brian0445
Oct 20, 2008 04:46 PM
Hellbender
All Things Towing
Jan 17, 2004 09:40 PM
