351 Backfires During Warm up
Old Jan 19, 2003 | 08:23 PM
Kodiak_Dan's Avatar
Kodiak_Dan
Question 351 Backfires During Warm up
My 1985 F-250 with a 351 starts right up but begins to backfire badly out the exhaust until it has reached operating temperature. The problem is made worse when the weather is wet. I suspect raw gas is being dumped somewhere but what would cause this? The distributor cap, rotor, wires, and timing are all good. Any help much appreciated!
Old Jan 21, 2003 | 09:18 PM
1984_355w's Avatar
1984_355w
Backfiring is usually a lean condidtion and that's why it happens when it's cold outside. Take a look at the plugs. Do you have glasspacks? If so, my '84 used to do it too. after the flows went on all of it went away.
Old Jan 22, 2003 | 10:40 PM
fastf150's Avatar
fastf150
Check the exhaust for any leaks you may have where it is sucking in exhaust somewhere. Also, if it is carb. check your choke make sure it working right.
Feb 9, 2015 03:39 AM
JPman90
Sep 30, 2008 04:38 PM
truckmano5-2
May 4, 2004 12:56 AM
puller1
May 23, 2002 06:56 PM
92EBBronco
1978 - 1996 Big Bronco
Apr 10, 2002 07:17 AM
