Did I break something?
Old Feb 15, 2010 | 09:29 PM
BodegaErik's Avatar
BodegaErik
Question Did I break something?
While backing my truck into my driveway today, I heard a "pop" and felt it in the steering. Immediately it felt as though I lost my power steering. Having lost it before due to a blown PS hose, I hopped out to see PS fluid all over. This wasn't the case. Curiousity had me take the truck around the block. Hard as ever pulling out of the driveway making a right hand turn. Down around the block I made all left hand turns, and all was fine.
So, left hand turns are easy, PS works great. Right hand turns are a pain, feels like no PS.
Is it possible for something to happen to the PS for right turns but not left turns? Or did I break a steering component that is now binding up when I make a right hand turn?
Any suggestions?
Old Feb 15, 2010 | 09:30 PM
BodegaErik's Avatar
BodegaErik
Forgot to add, the truck is a 1997 PowerStroke F-250 with about 200,000 miles.
Thanks.
Old Feb 16, 2010 | 01:09 AM
wheelie31's Avatar
wheelie31
look at your rack and pinion and steering stabilizer, i would think the pump is fine if it pumps fluid to move the one side fine
Old Feb 17, 2010 | 09:10 PM
BodegaErik's Avatar
BodegaErik
Haven't been able to check it out yet due to work.... I'll take a look this weekend. Thanks.
Old Feb 18, 2010 | 11:27 PM
mountaineer27's Avatar
mountaineer27
probably the power steering box. it has a valve inside of it that controls the pressure for witch ever way your turning. might be blown or stuck do to lack of fluid. just had mine do it last friday when the pressure line blew out of the fitting. one of fords dummest designs. there the only ones that use that set up.
Old Feb 18, 2010 | 11:38 PM
JCart's Avatar
JCart
Put it up on some jack stands and have a look, while someone turns the steering with engine running....do all safety precautions first.....
jrc
Old Feb 20, 2010 | 11:42 PM
BodegaErik's Avatar
BodegaErik
Does the fix for this require a new power steering box?
Thanks for the help.
Old Feb 21, 2010 | 02:59 AM
mountaineer27
i put a new one on but i have a couple trucks out in the yard. si it was no big deal. and mine the valve in it was in three pieces. i have no clue how much a new one would cost. probably a dealership order part$$$$. try a junk yard. i would think a gasser model would be the same. ill look it up in the chilton
