02 explorer 5r55w leaking
Old Feb 15, 2010 | 08:50 PM
lynnboy021's Avatar
lynnboy021
Trailering
Angry 02 explorer 5r55w leaking
here is the thing i was reading posts and stuff and they said when the tranny gets hot it leaks but in my case when i start up the truck it does not leak but after like 5 mins it starts leaking but the tranny fluid is cold not warm or hot then when i turn off the truck it stops leaking. so i bought a new pump and a new converter so maybe one of them is no good? the tranny has no problems shifting or anything truck only has 141,000 but it was a companey truck like a fleet truck and i bout it at action so dont know much about truck.. not making a sad story or anything but i have 3 babies and a wife stuff to pay and i dont have a job right now so its hard to buy parts (thanks god for ebay) i am a mechanic but not a tranny pro or tech i did rebuild my 700r4 tranny and it was really easy. i have alldata pro and i seen that ford has a tsb about the 5r55w tranny leaking from where mine is leaking but it says..... Article No.
03-5-7
03/17/03
TRANSMISSION - 5R55W - FLUID LEAK FROM THE
CONVERTER HOUSING AREA
FORD:
2002 EXPLORER
MERCURY:
2002 MOUNTAINEER
Article 01-11-05 is being republished in its entirely to update the Service Procedure.
ISSUE
This TSB supersedes 01-11-05 and is being reprinted to further clarify the diagnosis and repair procedures. Fluid leaks in the converter housing area must be diagnosed using the Leak Diagnostic Procedures found in the Workshop Manual.
ACTION
Fluid found to be in the converter housing area is not due to vent components but may be due to other transmission issues, i.e., transmission overheat, seal leaks etc. The vent service kit that was referenced in a previous TSB will no longer be available for purchase or usage as a repair component. If fluid is coming from the converter housing area follow normal diagnosis for fluid leaks as found in the Workshop Manual Section 307-01. If repairs are required, follow normal Workshop Manual procedures using the correct service part(s) as listed in your parts catalog.
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 01-11-05
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 504000, 510000
but i dont have a workshop manual to look at section 307-01...thanks and i am so so sorry about a long post... you guys rock
Old Feb 16, 2010 | 12:16 AM
Moto Mel's Avatar
Moto Mel
03-5-7
03/17/03
FORD:
2002 EXPLORER
MERCURY:
2002 MOUNTAINEER
ISSUE
ACTION
I have that section up on my computer and there is a ton of topics there. If you tell me what you want to see I can cut and paste the text but the pix, if any, will not load.
Also from your description it sounds like the the internal pump seal is leaking at the converter. Did you replace the converter and the seal? Did you check for a worn spot where the seal rides on the converter?
Old Feb 16, 2010 | 12:21 AM
lynnboy021's Avatar
lynnboy021
Trailering
all new maybe its coming from the vent tube? oh i also blow some air to the cooler and its not cloged
frt2599
6.7L Power Stroke Diesel
Oct 31, 2011 06:42 PM
captrivers
May 24, 2010 09:40 AM
YoGeorge
Modular V8 (4.6L, 5.4L)
Aug 27, 2008 11:02 AM
SC_Dave
May 1, 2008 08:42 AM
