TSB 11-10-10
Old Oct 28, 2011 | 01:54 PM
frt2599's Avatar
frt2599
TSB 11-10-10
Interesting TSB... Be careful where you put that DEF fluid.... There also looks to be a condition where they are replacing all eight injectors....
<TABLE border=3 cellSpacing=0 cellPadding=3 width="96%" itxtNodeId="31" itxtHarvested="0"><TBODY itxtNodeId="35" itxtHarvested="0"><TR itxtNodeId="37" itxtHarvested="0"><TD bg*************** width="25%" align=middle itxtNodeId="41" itxtHarvested="0">TSB
11-10-10
</TD><TD bg*************** width="65%" align=left itxtNodeId="40" itxtHarvested="0">
  • 6.7L DIESEL - RUNS ROUGH/ENGINE CRANKS-NO START - DTCS P1291 AND/OR P1292
</TD></TR><TR itxtNodeId="36" itxtHarvested="0"><TD bgColor=#0000ff colSpan=2 itxtNodeId="47" itxtHarvested="0">[************]Publication Date: October 10, 2011[/COLOR]</TD></TR></TBODY></TABLE>
<TABLE border=0 itxtNodeId="29" itxtHarvested="0"><TBODY itxtNodeId="50" itxtHarvested="0"><TR itxtNodeId="51" itxtHarvested="0"><TD width=230 itxtNodeId="53" itxtHarvested="0">FORD:
</TD><TD itxtNodeId="52" itxtHarvested="0">2011-2012 F-Super Duty</TD></TR></TBODY></TABLE>
This article supersedes TSB 11-6-10 to update the vehiclemodel years, Issue Statement, Service Procedure, Service Labor Time Standards and Part List. ISSUE:
Some 2011-2012 F-Super Duty vehicles equipped with a 6.7L engine may exhibit diagnostic trouble codes (DTC) P1291 and/or P1292 due to an internally shorted fuel injector. An internal short in a fuel injector may be caused by the fuel being contaminated with diesel exhaust fluid (DEF), or by fuel gelling.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
  1. [*]
  2. [*]
<TABLE border=1 cellSpacing=0 cellPadding=3 itxtNodeId="16" itxtHarvested="0"><TBODY itxtNodeId="91" itxtHarvested="0"><TR itxtNodeId="95" itxtHarvested="0"><TH align=middle itxtNodeId="97" itxtHarvested="0">PART NUMBER</TH><TH align=middle itxtNodeId="96" itxtHarvested="0">PART NAME</TH></TR><TR itxtNodeId="94" itxtHarvested="0"><TD align=left itxtNodeId="99" itxtHarvested="0">BC3Z-9A564-A</TD><TD align=left itxtNodeId="98" itxtHarvested="0">Injector Return Hose</TD></TR><TR itxtNodeId="93" itxtHarvested="0"><TD align=left itxtNodeId="101" itxtHarvested="0">BC3Z-9H529-A</TD><TD align=left itxtNodeId="100" itxtHarvested="0">Fuel injector (Cylinders 1, 2, 7, 8)</TD></TR><TR itxtNodeId="92" itxtHarvested="0"><TD align=left itxtNodeId="103" itxtHarvested="0">BC3Z-9H529-B</TD><TD align=left itxtNodeId="102" itxtHarvested="0">Fuel injector (Cylinders 3, 4, 5, 6)</TD></TR></TBODY></TABLE>
WARRANTY STATUS:
Eligible Under Provisions Of NewVehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
<TABLE border=1 cellSpacing=0 cellPadding=3 itxtNodeId="12" itxtHarvested="0"><TBODY itxtNodeId="105" itxtHarvested="0"><TR itxtNodeId="109" itxtHarvested="0"><TH align=middle itxtNodeId="112" itxtHarvested="0">OPERATION</TH><TH align=middle itxtNodeId="111" itxtHarvested="0">DESCRIPTION</TH><TH align=middle itxtNodeId="110" itxtHarvested="0">TIME</TH></TR><TR itxtNodeId="108" itxtHarvested="0"><TD align=left itxtNodeId="115" itxtHarvested="0">111010A</TD><TD align=left itxtNodeId="114" itxtHarvested="0">2011-2012 F-Super Duty 6.7L SingleRearWheel: Inspect Fuel Conditioning Module, Engine Wiring Harness, Test And Replace The Fuel Injectors, And The Injector Return Hose</TD><TD align=left itxtNodeId="113" itxtHarvested="0">4.7 Hrs.</TD><TR itxtNodeId="107" itxtHarvested="0"><TD align=left itxtNodeId="118" itxtHarvested="0">111010B</TD><TD align=left itxtNodeId="117" itxtHarvested="0">2011-2012 F-Super Duty 6.7L Dual Rear Wheel: Inspect Fuel Conditioning Module, Engine Wiring Harness Test And Replace The Fuel Injectors, And The Injector Return Hose</TD><TD align=left itxtNodeId="116" itxtHarvested="0">4.9 Hrs</TD><TR itxtNodeId="106" itxtHarvested="0"><TD align=left itxtNodeId="121" itxtHarvested="0">MT111010</TD><TD align=left itxtNodeId="120" itxtHarvested="0">Claim Actual Time For Engine Wire Harness Repairs</TD><TD align=left itxtNodeId="119" itxtHarvested="0">Actual Time</TD></TR></TBODY></TABLE>
DEALER CODING
<TABLE border=1 cellSpacing=0 cellPadding=3 itxtNodeId="10" itxtHarvested="0"><TBODY itxtNodeId="122" itxtHarvested="0"><TR itxtNodeId="124" itxtHarvested="0"><TH align=middle itxtNodeId="126" itxtHarvested="0">BASIC PART NO.</TH><TH align=middle itxtNodeId="125" itxtHarvested="0">CONDITION CODE</TH></TR><TR itxtNodeId="123" itxtHarvested="0"><TD align=middle itxtNodeId="128" itxtHarvested="0">9a564</TD><TD align=middle itxtNodeId="127" itxtHarvested="0">42</TD></TR></TBODY></TABLE>
<HR itxtNodeId="9">NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2011 Ford Motor Company
Old Oct 28, 2011 | 02:21 PM
Tom's Avatar
Tom
Very informative, thanks for posting.
Added to tech folder!
Old Oct 29, 2011 | 04:39 AM
kabur66's Avatar
kabur66
Thanks for the good info.
Old Oct 30, 2011 | 12:30 PM
porthole's Avatar
porthole
Good to know and now all the more reason to keep spare filters on hand.
Old Oct 31, 2011 | 06:14 PM
cirrus365's Avatar
cirrus365
There must have been quite a few people putting DEF in the fuel tank to put out TSB.
Old Oct 31, 2011 | 06:42 PM
Tom's Avatar
Tom
I don't know about that. I don't think it would take many $10K repair bills due to customer negligence for Ford to wise up to the problem.
Stuff like this is great for people to know though. Knowledge of the damage DEF can cause just saved 6.7Fan a LOT of money!
bismic
Jul 12, 2016 01:11 PM
makuloco2000
Jan 26, 2014 09:51 PM
immastrokinnow
Jan 3, 2009 04:27 PM
