blinker problem solved
Old Feb 15, 2010 | 02:58 PM
marks69's Avatar
marks69
hi guys. today i put led bulbs in all the turn, stop, backup bulbs. now the lights work great, except when i have the headlights on the blinkers don't blink. worked fine before. mabye i need a different blinker on the fusebox? i tried swapping the hazzard and blinker with no luck. the weird thing is the hazards work?lol
any ideas?
thanks
mark
Old Feb 16, 2010 | 03:08 PM
marks69's Avatar
marks69
put in an electronic blinker today and it works better. still seems to blink slowely though.
Old Feb 18, 2010 | 05:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is a blinker? Do you mean the turn signal flasher?
There are TWO flashers used on these trucks. One for the turn signals, a H/D version for the 4 way emergency lamps.
The H/D flasher can also used for the turn signals, was usually installed when towing, or if someone was hard of hearing.
The H/D flasher has a much louder "click" to it.
Old Feb 18, 2010 | 12:11 PM
tooNz213's Avatar
tooNz213
wish i could help
Old Feb 18, 2010 | 02:39 PM
marks69's Avatar
marks69
yes i meant the flasher.
seems to work fine now. the next step would have been to put a resistance wire at every bulb.
Old Feb 19, 2010 | 05:07 AM
jowilker's Avatar
jowilker
Don't fret over it Bill, Ford didn't make LED flashers or blinkers for that year, your answer would be OBSOLETE.
John
Old Feb 19, 2010 | 05:16 AM
marks69's Avatar
marks69
you were just dying to say that weren't you.lol
Old Feb 19, 2010 | 11:58 AM
NumberDummy
My point was...since there are TWO flashers behind the dash, which one did the OP replace?
Some people haven't a clue these trucks use two flashers, so...
They replace what they think is the turn signal flasher, which doesn't solve the problem with the turn signals...because they replaced the emergency flasher instead.
How could a part be obsolete...if it does not exist?
Old Feb 19, 2010 | 03:30 PM
xstrange's Avatar
xstrange
Speaking of the hazard flashers, I was amazed the first time I opened the glove box on my '67 F100, and found that the switch for them was in there! Was that another one of those silly '67 only things?
Old Feb 19, 2010 | 08:30 PM
gangstakr's Avatar
gangstakr
An LED flasher is needed. There more expensive but that's what happens when you go to led's
Old Feb 19, 2010 | 10:12 PM
NumberDummy
Believe it...or not, all 1967/72's have the 4 way emergency flasher switch mounted inside the glove box on a bracket.
Old Feb 19, 2010 | 10:36 PM
DarrellJ's Avatar
DarrellJ
Bill,
That's an interesting comment, since the emergency flasher on my 67 with 68 cab is on the dash beside the choke. The little bezel says 'Emergency'. I assumed it was stock.
Today I moved it to the glove box (using stuff from my 67 parts truck), to free up a spot for Cargo Light/Rock lights.
What three things are supposed to be the right side of the dash? Choke,Emergency,Lighter is how my dd is. Choke, Big Ugly Red **** (probably cargo light?), Lighter on my parts truck.
I know a cargo light was available, what did the **** look like?
darrell
Old Feb 20, 2010 | 02:23 AM
Lvcrprts's Avatar
Lvcrprts
Yep my 68 has it in the glove box. Sure its not low on blinker fluid? Dad used that one on me when i was younger along with me asking for a muffler bearing at the muffler shop. My hearing is getting worse maybe i need one of those loud clickers to keep me from signaling left for 5 miles. Gonna go with the led replacements from LMC myself but LED is a must for people to see your lights that will keep a great old truck from the scrapyard. Just my .02
Old Feb 20, 2010 | 09:24 AM
68horses's Avatar
68horses
FWIW,
Late 70's early 80's Mopar "K" cars actually had parts listed in the parts catalogue as "Muffler Bearings"
Gene
Old Feb 20, 2010 | 10:18 AM
mailmandon's Avatar
mailmandon
led flashing problem
LEDs use practically no electricity as compared to a regular bulb.I would think that would cause the no flash problem that some people encounter when changing to LEDs.The circuit might not sense there is a working bulb there.Some replacement LEDs have a circuit built in to overcome this.
My 2¢.
