Decode rear axle
Old Feb 15, 2010 | 09:36 AM
Tnkgunner's Avatar
Tnkgunner
Decode rear axle
I have a 2008 F150 XLT 4x4 need to decode rear axle tag V8 Auto. Would like to find real web site with this info. most are not up to date
Thanks Tnkgunner
Old Feb 15, 2010 | 11:43 AM
390XR7's Avatar
390XR7
try this site might help you with what your looking for.
https://www.ford-trucks.com/article/idx/7/017/article/Ford_Door_Sticker_Decoder.html
Old Feb 17, 2010 | 01:05 AM
goracer's Avatar
goracer
XLT should have the 9.75 rear end. FX4's have the larger size. The sticker on the door will tell you what axle size you have after you decode it. I beleive it's a letter that you need to translate to a number.
Old Feb 17, 2010 | 02:51 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
4.6 2v motor = 8.8 axle
5.4 3v motor = 9.75 axle
5.4 3v motor with Heavy Duty package = 10.25 axle (7 lug)
what does your door sticker say in the axle part? that part is what tells you whether you have a 3.55, 3.55LS, 3.73, 3.73LS, or 4.10 (heavy duty only) gearset
Old Feb 17, 2010 | 02:58 AM
goracer's Avatar
goracer
Oh yes sorry. Thanks Tylus. XLT is 3.55 (mine is LS) and FX4 is 3.73(LS). I mixed that up with the axle size.
Old Feb 17, 2010 | 11:56 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
not exactly goracer
some XLT's have 3.73...but the majority are 3.55. and not all FX4 are 3.73...if you bought a FX4 Lux with 20's, it was supposed to have 3.55 gears.
the only 100% factor is the axle size. after that, you must look-up the door sticker tag for the gearset
Old Feb 22, 2010 | 11:01 AM
Tnkgunner's Avatar
Tnkgunner
Thank you for the info It turned out to be an 8.8 with 3.73 now could anyone tell me if 2008 axle shaft will fit into a 2001 f150 rear end . Other then the 5 lug to six lug. I know where I can get a new rear end rotor to rotor from a 2001 f150 from a closed dealership. would need to change axles for the six lug, or did they change the bearing size. Thanks "Tank"
awhtx
Large Truck
Apr 14, 2017 06:21 PM
duallyhauler
Jan 5, 2013 11:36 PM
old hippy
Nov 10, 2012 08:47 AM
is300wrx
2004 - 2008 F150
21
Aug 25, 2009 07:26 PM
ANG&STEVES F350
Dec 9, 2006 08:57 AM
