lower radiator hose
Old Feb 14, 2010 | 09:06 PM
zaaac's Avatar
zaaac
lower radiator hose
This '79 Supercab 4x4 F150 I picked up has the bottom rad hose rubbing on the crossmember. I bought another hose thinking it had the wrong one on. The new hose is the same way. If I twist it so it doesn't touch the crossmember then it rubs the P/S belt. It is a tight fit between the crossmember and the P/S belt. Parts guy said there was no difference between the Supercab with leaf springs and the regular cab with coil springs. Has anyone else had this problem? Thanks.
Old Feb 15, 2010 | 12:14 AM
montana_highboy's Avatar
montana_highboy
Cut a section of old hose to wrap the new hose where it rubs against the crossmember.
Old Feb 15, 2010 | 12:32 AM
zaaac's Avatar
zaaac
Did that...lol. Just wondering if I'm the only one with that problem.
Old Feb 15, 2010 | 02:30 AM
Dirt racer's Avatar
Dirt racer
I 2nd that. I have alot of stuff on my vehicles with extra rubber put in for things that rub. Works great. I always save my old hoses just for this.
Old Mar 3, 2010 | 07:38 PM
zaaac's Avatar
zaaac
I looked at a couple other '79's and the coil spring ones have a different front cross member than my leaf spring F-150 and the lower rad hose doesn't rub on them. The parts guy said it showed only one lower rad hose; no difference for regular cab or super cab. I find it hard to believe Ford built these trucks with the hose rubbing. Numberdummy, can you tell me if there is a specific hose for the 1979 F150 Super Cab 4x4, 400 CID, p/s, no a/c? Thank you sir.
f350rebel
Mar 13, 2025 06:02 PM
Bigblue351
May 16, 2012 10:34 AM
BossFan
Oct 22, 2011 01:49 PM
Rogue427
Mar 25, 2009 11:14 AM
dichdoc
Nov 13, 2007 10:32 PM
