Belt rubbing on lower radiator hose?
11-13-2007, 07:02 PM
on
AC/ PS belt rubbing on lower radiator hose. 1993 F 250 auto 460. Has had a motor rebuild. Motor mounts bad? or Bearing???
11-13-2007, 07:39 PM
Might be the bottom radiator hose is on backwards. Swap it end for end & see if that doesen't help.
11-13-2007, 08:09 PM
on
It actually rubbing right over the hose clamp. Seems to be some kind of cast aluminium "y" thing that it clamps onto. TB
11-13-2007, 08:39 PM
Can you spin the clamp around?
11-13-2007, 10:27 PM
on
It's not rubbing on the screw part of the clamp but a smooth surface of the band.
11-13-2007, 10:32 PM
sounds like a bad motor mount if ya ask me thats about the only thing i know it could be do you know if they replaced the mounts when they pulled the motor ????
Ron94150
10-05-2015 11:28 AM
daybo13
2009 - 2014 F150
11-30-2014 06:23 AM
The Terrible Blob
07-22-2014 12:22 PM
DGMFORD
01-11-2014 10:24 AM
