Sponsored by: Real Truck
Spare tire removal
Old Feb 14, 2010 | 08:23 PM
Johan6966's Avatar
Johan6966
Spare tire removal
I dont have the factory tool for it. Is it a torque tip bit?
Old Feb 14, 2010 | 08:35 PM
mrford60's Avatar
mrford60
what year is your truck? 99 and up should have a lock on it, i am guessing you dont have that either.
Old Feb 14, 2010 | 09:04 PM
bunklash's Avatar
bunklash
Do a search, covered in the past. It takes a key on the end of the crank handle. I got my spare down by jamming a socket over the adapter using a real long socket extension and lateral pressure. Others have used stripped bolt removing tool. Once you get the tire down, you can remove the adapter and not have to worry again.
Good luck!
Old Feb 14, 2010 | 09:14 PM
Johan6966's Avatar
Johan6966
yeah sorry its an 05, i can see down the tube its def some sort of locking device like on aftermarket rims but almost looks torque tip ish.
Old Feb 14, 2010 | 09:50 PM
Lubbockguy1979's Avatar
Lubbockguy1979
9/16 inch socket fits over the locking device. Go to harbor freight get a $,50 socket hammer it on and leave it. Then use a socket wrench to raise and lower it. Or a drill as I do.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
