High idle
Old Mar 8, 2010 | 06:47 PM
97ranger xlt's Avatar
97ranger xlt
Originally Posted by Diesel_Brad
I lied. My high idle prob is still there. I replaced the PCV, TPS, IAC and checked for vaccume leaks and found nothing. Driving down the road if you push in the clutch the RPMs will drop to,2k and stay there with my foot off the gas. Will stay there for at least 30 sec.
Any more ideas
did you clean the MAF and reset the ecu?
Old Mar 9, 2010 | 05:40 PM
Diesel_Brad's Avatar
Diesel_Brad
How do you clean the MAF?
Here is pics of what i pulled from the passenger valve cover(on the left) and what i put in its place(on the right). No difference in how it runs at all.
Old Mar 9, 2010 | 06:08 PM
97ranger xlt
you can clean the MAF with electronics cleaner (can get at radio shack) or maf cleaner from any autoparts store.
those pics look like a breather valve.
the only other thing that i could suggest that could effect idle would be the IAT sensor in the intake
but having said that after replacing all those other parts did you reset the ecu?
Old Mar 9, 2010 | 07:36 PM
Diesel_Brad
WELL i cleaned the MAFw carb cleaner. The test drive seemed to act like it hepled. Woulnt really know till i take my 100 mile ride to work in the am.
And yes. i disconneced the battery for 10 min
Old Mar 9, 2010 | 08:35 PM
97ranger xlt
Thumbs up
yes see what happens tomorrow after the computer relearns the air/fuel trim etc.
if you can, do a couple of wide open throttle spurts and then lift and engine brake off an exit all the way down to idle.
hope it works for you...
Old Mar 10, 2010 | 04:49 PM
Diesel_Brad
Nope. Didn't fix $#!+. But it is a lil pepier now. But still has idle of about 2k when crusing down the highway. This truck is pissing me off. I am almost tempeted to take it to a dealer
Old Mar 10, 2010 | 05:28 PM
97ranger xlt
please help me out here you did replace the PCV valve underneath the intake manifold right? the part you showed in the pic was not it....
Old Mar 10, 2010 | 05:39 PM
wtroger's Avatar
wtroger
Folks there is only 3 ways to get a high idle condition.
1. Throttle is not closing all the way.
2. Iac is not functioning properly Ie: stuck open
3. Massive vacuum leak
Old Mar 11, 2010 | 09:22 PM
Diesel_Brad
Under the intake manifold? As in i have to remove the intake manifold to replace it?! Do you have a pic of what it looks like?
Old Mar 12, 2010 | 06:24 AM
97ranger xlt
sorry looking again that pic you showed did look like the pcv. did
you check the vac line attached to it? mine was leaking and caused
high idle. again my bad the 2.3 engine's pcv is located under the manifold
..forgot yours is the 4.0...
Old Mar 12, 2010 | 07:42 AM
Diesel_Brad
1 The throttle closes all the way in my driveway(have no way to check while driving down the road) I can snap the trottle and the RPMs do not drop.
2.I am thinking that is the problem but there is so many things that control it.
3. I cant find any vacuum leak w carb cleaner so i think i ruled that out
NewEnglander
1978 - 1996 Big Bronco
Oct 17, 2016 01:50 PM
tomanycars
Electrical Systems/Wiring
Apr 11, 2016 08:02 PM
snake8myelbo
13
Jan 13, 2016 11:08 AM
Turtlebeach
Nov 5, 2015 09:18 PM
deddy
Sep 8, 2009 12:00 PM
