refuses to crank!!!
Old Feb 14, 2010 | 04:29 PM
adamax21's Avatar
adamax21
refuses to crank!!!
i took the serp belt off to lessen resistance, but will my 96 7.3 psd still crank without it?? ive got two 900 cca amp batteries that i know are hot, but it still takes only about 6-8 sec for the motor to stop cranking over.. any ideas??
Old Feb 14, 2010 | 04:31 PM
wheelie31's Avatar
wheelie31
yes it will still crank,No idea on why it might stop cranking though
Old Feb 14, 2010 | 04:47 PM
rideracelivemx7's Avatar
rideracelivemx7
Lesson the resistance for..... I hoppe you don't plan on driving wiyh out the belt lol I don't know what your treying to accomplish, what will cool the motor or keep the batteries charged or run the vaccum system or give you steering?
Old Feb 14, 2010 | 04:56 PM
Cudaguy's Avatar
Cudaguy
I'd replace all the battery cables. My starter cable had come loose from the factory terinal, so I cut the insulation to put a regular terminal, and the copper wire was already turning green. I am running it like that for now, but will be replacing it this month. My tractor's positive cable also needed replacing last mont for the same thing. It looked prefect from the outside, but was toast on the inside.
adamax21's Avatar
adamax21
the goal for right now is just to get it crunk.... once it will reliably crank, THEN ill put the belt back on and hopefully drive it down the road...
Old Feb 14, 2010 | 06:26 PM
yoslick's Avatar
yoslick
cables or starter, I'd start with your cables, very common for them to rot from the inside out due to too many amps......
ford collector
Dec 6, 2012 08:00 AM
vwfreak
WTB - Parts & other
Nov 21, 2012 07:50 PM
F150Poke
1997 - 2003 F150
Oct 12, 2012 10:06 PM
leoparleur
1983 - 2012 Ranger & B-Series
Nov 11, 2008 06:16 PM
DubDub
19
Jan 28, 2008 04:36 PM
