TC Actin Funny
Old Feb 14, 2010 | 10:58 AM
97biostroke's Avatar
97biostroke
TC Actin Funny
I made a post not too long ago with this problem. At first the torque converter would randomly unlock around 45-50 mph, but i was driving through some slushy roads and figured it was extra drag causing it to shift down. Now it still does it. It happens anywhere from 45-70 mph and just randomly unlocked for a few seconds. Even happened at 30 mph yesterday. About two months ago it would unlock when I used my right turn signal but it stopped doing that after a day so i didnt worry about it. Any ideas what might be causing this? I just got a new torque converter put it about two months ago.
Old Feb 14, 2010 | 01:00 PM
magneto259's Avatar
magneto259
My truck would do that while i was towing my boat. The wiring on the boat trailer was screwed up. When I would hit the brakes or use my turn signal it would unlock. Are you by chance towing anything?
DRRXR's Avatar
DRRXR
Check your wiring at the accumulator for bad spots. Check to ensure that the pins are clean and free of water. Put some dielectric grease on the outer sealing area of the connector. Check the purple wire w/yellow stripe for issues. make sure your pcm is sealed.
Old Feb 14, 2010 | 02:10 PM
cowmilker08's Avatar
cowmilker08
definately sounds like a short.
remember the torque converter locks when it gets no electricity from the pcm.
Old Feb 14, 2010 | 06:44 PM
97biostroke
Where might I find the accumulator?
Old Feb 15, 2010 | 09:15 AM
DRRXR's Avatar
DRRXR
Passengers side of the transmission pan locate the wiring harness connector and the wire the is purplpe w/yellow stripe. Check to ensure that there is no grounding of the wire via bad insulation. Carefully remove the connector and check for moisture. Dry it out well and use some dielectric grease to seal the the inner edge of the connector. The pan covers the accumulator and seloniod packs.
Ford Truck Enthusiasts Forums - DRRXR's Album: E4OD
Old Feb 15, 2010 | 06:31 PM
97biostroke
Alright thanks for the help guys ill give it a shot
Old May 3, 2010 | 06:51 PM
cowmilker08
Does anyone know how this turned out?
Today when I turned on my right turn signal, the Torque Converter would unlock.
Old May 3, 2010 | 08:27 PM
Hussler's Avatar
Hussler
Did it to me a couple months ago with right turn signal also. Guy at work was following me and told me my left tail light was out, it was early morning and dark outside. Bulb was bad, replaced it and all is well .. go figure.
Old May 3, 2010 | 09:25 PM
cowmilker08
Haha, Oh my!
Well my left tail light is still working, but not the brake/turn-signal on the left rear.
I'll start with that.
LOL, for some reason I can't stop laughing.
Old May 5, 2010 | 09:18 AM
cowmilker08
Well, I replaced the bulb, and problemo solvo.
I still think it funny though.
Left rear turn light goes out, right turn signal unlocks torque converter. LMAO.
Old May 5, 2010 | 09:35 AM
superduty4x4's Avatar
superduty4x4
For some reason the torque converter can get cranky if you have a burned out brake or turn signal bulb. So that is always an easy first thing to check if you start having problems. If you have LED's installed they can cause problems too unless you put a resistor in the wiring to simulate the current draw of an incandescent bulb.
Central Texcursion
Jul 3, 2013 06:37 AM
fordno1
16
Dec 16, 2012 08:06 AM
97biostroke
Feb 9, 2010 10:47 PM
jdap
22
Jun 12, 2008 06:53 PM
fmr9
Jun 15, 2006 12:32 AM
