shock location
Old Feb 13, 2010 | 10:37 PM
GwarForAll1021's Avatar
GwarForAll1021
shock location
can anybody tell me why the shocks are located outside the frame rails? no other truck does this and goes against un sprung weight...
just strange i cant see a good reason for them to be there. expecially if you have a tire blow out and take out your new high dollar shock.
Old Feb 14, 2010 | 01:24 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
by placing the shock that far outward on the axle, Ford was able to give the suspension alot more rigidity vice the traditional method.
it's all about leverage. outboard the frame, you get a ton more
read up some interesting stuff on the 04-08 trucks - 2004 Ford F150 Overview
"The Hotchkiss-design rear suspension has been optimized with rear shock absorbers placed outboard of the frame rails - a segment exclusive - for improved control of body lean and a smoother ride. The shock position also provides better control of axle "skipping" and "skating" that can happen on washboard-type surfaces. Rear leaf springs are now 3 inches wide (20 percent bigger than the 2002 F-150 and the same width as on the F-Series Super Duty lineup) to help reduce sway during cornering and considerably improve towing stability"
Old Feb 14, 2010 | 08:40 AM
shorebird's Avatar
shorebird
Here is why Ford places the shocks outside the frame. Watch the bed on the Tundra shake in relation to the cab.
YouTube - 2009 Ford F150 Vs. 2008 Toyota Tundra
Old Feb 15, 2010 | 10:09 AM
wolf189's Avatar
wolf189
wow! that video definitely shows the difference in how the two trucks ride over rough/uneven pavement. should use that in a Ford commercial.
Old Feb 15, 2010 | 02:04 PM
Gearbanger 101's Avatar
Gearbanger 101
Actually, they did. The ones with that Mike Rowe guy.
You wanna see something else that'll turn your stomach about the Toyota, take a look what happens when they compare the frames between the two trucks.
<param name="movie" value="http://www.youtube.com/v/zRfE_XAk2mE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zRfE_XAk2mE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed>
marquiesj
Oct 18, 2009 09:41 PM
mikesmayhem
Apr 3, 2009 10:19 AM
I_Love_Cheese
Jun 5, 2007 02:07 PM
skinner4192
Jul 22, 2003 12:47 PM
jcmagone
Mar 15, 2002 11:13 AM
