6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
VERY rough idle, check engine light
Old Feb 15, 2010 | 11:10 PM
ssharber's Avatar
ssharber
Just wondering, since this is my first diesel, what would I experience if I started having trouble with my EGR valve, or if there's something I can look out for which might be leading up to an EGR issue but not having symptoms yet? My truck is running fine, but I do alot of driving currently without pulling a trailer. I bought the truck because I WILL BE pulling trailers and such a little in the future but with everyone saying if you don't pull with it NOW you'll have problems it's just got me a little worried. I mean I drive it hard at times and put a load on the engine, but as far as pulling I dont do a whole lot of it at the present time.
Old Feb 16, 2010 | 05:09 AM
koboss1's Avatar
koboss1
what i noticed is that the truck would go into limp mode cause to hot im guessing and just have minimum power like none at all.
other than that is just quit
Old Feb 16, 2010 | 05:16 AM
senix's Avatar
senix
As long as your driving is lenthy and get that motor hot, a couple WOT 2K rpms, I would not worry about it.
Driving at 30 mph and sitting at stop lights constantly is what is gonna kill it.
Old Feb 16, 2010 | 09:24 AM
boulderbronco's Avatar
boulderbronco
Mine gave me no warning at all. Was running great. Parked it for an hour. Came out to leave and it just wouldn't run.
Old Feb 16, 2010 | 01:04 PM
ssharber's Avatar
ssharber
Thanks guys. I definitely don't let her idle much at all, and I never take her out for short trips. She gets good and hot and I always run her wot for a while every time I'm in her. (Maybe I should reword that. Almost sounds a little dirty)
Old Feb 19, 2010 | 07:37 AM
sd convert's Avatar
sd convert
Just like boulder said mine to was running good ,shut off to load up a trailer and would start but ran rough and would not go forward in gear(no power).engine check light came on. I have not heard of any signs or symptoms before valve becomes stuck open.
Artie Gustafson
2004 - 2008 F150
Mar 7, 2016 07:27 PM
collinrandle
16
Nov 17, 2015 01:13 AM
ViperGTSR6
Sep 23, 2015 10:57 PM
GRNMSTR
Escape & Escape Hybrid
Nov 3, 2011 05:27 AM
nytreeman
Apr 16, 2010 05:19 PM
