Sponsored by: Real Truck
Rim Question
Old Feb 12, 2010 | 07:46 PM
devink's Avatar
devink
Rim Question
Can anyone too me if the rims off of a 2008 will fit my 2004?
Old Feb 12, 2010 | 08:15 PM
strokin83's Avatar
strokin83
No the offset is different they changed it in '05. Maybe if you had some spacers it would work.
Old Feb 12, 2010 | 08:22 PM
devink's Avatar
devink
Thanks, do you know where to research the spacers I would need? How much would this change my speedometer?
Old Feb 13, 2010 | 01:55 AM
Bustaduck's Avatar
Bustaduck
rims
I'm going through the sme thing. 2" metal spacers well run you around $600 new rims are what I'm going to do so if anybody needs some factory 08 rims I'VE got a set look brand new
Old Feb 13, 2010 | 08:26 PM
78bigbronco's Avatar
78bigbronco
Rims and spacers dont have anything to do with your spedo... the outside diameter of the tire will. You have to know what size tire you had and compare that to the tire size your going to and see if there is a difference.
This calculator I have found quite handy when dealing with tire sizes:
Tire size calculator
Old Feb 13, 2010 | 08:43 PM
devink's Avatar
devink
Lets see............I have an 04 (16" rims) and I am looking at 08 (17") rims...........Uh I think that qualifies as the tires being a different size.
Thanks for the calculator though...........
Old Feb 14, 2010 | 12:41 AM
TRS's Avatar
TRS
Your the one that asked if it would change your speedometer. The guy was answering your question for you.
Old Feb 14, 2010 | 02:55 AM
78bigbronco
Not sure what you mean. Rim size has nothing to do with tire size, I mean you can have just about any tire size you want on 16, 17, 18, or whatever size rims... Even if you stick with just the stock tires I think there a various sizes, for example in 04 I think one of the common tire sizes were 265's. In that case your 04 would have a larger sized tire than my 09 not the other way around, in both width and hieght. Mine only has 245's. And if your buying new tires you can throw on any number of sizes...
