Towing
Old Feb 12, 2010 | 09:39 AM
jfoltz's Avatar
jfoltz
Towing
I'm going to possibly be buying a second truck to serve as a parts truck. The second truck is currently not drivable so it needs to be towed about 110 miles or so. Does anyone know if I can pull an 83 F-100, 2WD with an 86 F-150 2WD using a car dolly? The 86 has the straight 6 with a four speed manual tranny.
I can't do a flat tow because the one tire won't hold air. I've read in some places where they recommend only towing a RWD vehicle in a car trailer. Is this good advice?
Old Feb 12, 2010 | 10:04 AM
Redneck1465's Avatar
Redneck1465
I wouldnt. The two dolly probably wouldnt be wide enough to fit the other truck on it. I would get a tire for the one your towing and either put it up on a trailer or use a tow bar. I have had really good luck with tow bars. Plus you wont find anyone to rent you a dolly because the vehicle your towing with isnt significantly heavier than the vehicle you planning on towing.
Old Feb 12, 2010 | 10:14 AM
jfoltz's Avatar
jfoltz
Yeah, I think you're right. I'm leaning towards a tow bar because the 86 only has a bumper hitch and I don't have the money to install a regular hitch right now. So I'm thinking a full car trailer wouldn't work well either.
Old Feb 12, 2010 | 10:18 AM
Redneck1465
Yeah there would be no way I would pull that much weight with only a bumper hitch. Its just not safe at all.
Old Feb 12, 2010 | 12:38 PM
Franklin2's Avatar
Franklin2
If you flat tow, I would take the driveshaft out of the towed vehicle. Flat towing a automatic tranny vehicle that far usually ruins the tranny, and there is one 4 speed tranny Ford has that should not be flat towed either, so just to be safe I would pull the driveshaft.
Old Feb 14, 2010 | 08:47 PM
Redneck1465
Without a doubt disconnect the drive shaft from the axle but do not pull it from the transmission otherwise you will loose a bunch of fluid from the trans. Just strap it up on the side so that its still there just not connected to the rear end.
-jb-
Mar 9, 2012 10:12 PM
plaman
All Things Towing
May 13, 2011 09:16 AM
jlcote
Aug 9, 2009 08:57 PM
IowaTower
Feb 13, 2006 08:44 PM
scottie2hottie
All Things Towing
21
Sep 23, 2004 08:42 PM
