intercooler?
Old Feb 11, 2010 | 08:11 PM
dougbrown's Avatar
dougbrown
intercooler?
Whats is the Intercooller and what doesit do for our trucks? I have read alot of people add them but never knew why? Could you guys fill me in about them.
Thank you
-Doug
Old Feb 11, 2010 | 08:59 PM
fishmanndotcom's Avatar
fishmanndotcom
intercooler takes the air from the input side of the turbo routes it to a heat exchanger (the big radiator looking thing in front of the radiator) to cool off the air and then routes it to the output side of the turbo. this helps keep the turbo temps down so when you romp on the motor esp with HP gaining mods you dont melt the turbo down.
this can also be accomplished using water/meth injection
EDIT... here is Wiki's definition, lol, way more techinical than mine
http://en.wikipedia.org/wiki/Intercooler
-cutts-
Old Feb 11, 2010 | 09:22 PM
dougbrown's Avatar
dougbrown
Do the newer 99 to 02 Powerstrokes have them? How had is it to install?
Old Feb 11, 2010 | 09:25 PM
Andy's250's Avatar
Andy's250
yes they came stock on them. we use the spyder piece off a early 99 to convert ours because the intakes and the turbo are the same size as ours
Old Feb 11, 2010 | 09:29 PM
jchosler's Avatar
jchosler
if you have stage II's and a chip, is it a good idea to install the intercooler?
Old Feb 11, 2010 | 09:33 PM
dougbrown's Avatar
dougbrown
It stock beside the cold air intake.
Old Feb 11, 2010 | 09:41 PM
Cudaguy's Avatar
Cudaguy
Intercooler lowers the air going into your engine after the turbo, which happens to compress (and heat) air. Compressed air is good, but better when cooled. An added benefit of an IC is it allows you to safely burn more fuel thus making more power, while keeping egt's at a safe level. Ultimately, all it is is a radiator fot the air you pump into and out of your engine.
Old Feb 11, 2010 | 10:35 PM
blue66tang95f150's Avatar
blue66tang95f150
Intercooler - Wikipedia, the free encyclopedia
-cutts-
I thought the inter-cooler was after the turbo and just before the air goes into the engine. So I don't think it cools the turbo down, just the air going into the engine. When air is compressed it creates heat, so it needs to be cooled. Thus it must come after the turbo has already compressed the air. Am i correct, or am I just retarded and have no idea what I am talking about?
Old Feb 12, 2010 | 06:34 AM
fishmanndotcom
thats a good quiestion, i am not sure now that you bring it up. thats just how i always understood it. hopefully someone who knows will chime in.
-cutts-
Old Feb 12, 2010 | 07:48 AM
f-250diesel's Avatar
f-250diesel
Well i dont think mines has a intercooler and i want to put one one becuase i run my truck hard as hell. If any one has one and they want to sell it let me know, also it said that you can put a stock one from a 99 or so and put it on the olders mine is a 1995 can i find a used one and put it on mine.
Old Feb 12, 2010 | 07:53 AM
427 fordman's Avatar
427 fordman
It's a real good idea or you will be putting out some high egt's I would think. According to your sig you already have these things. I'd get some guages quick to keep track of temps so you know. If they are high, get yourself an ic. You really don't want to melt down some pistons too bad
Old Feb 12, 2010 | 10:23 AM
MagKarl's Avatar
MagKarl
As the intake air is compressed by the turbo, it is heated up. The hot compressed air is routed through the IC in front of the radiator to cool it before the air is consumed by the engine. The lower temperature air helps keep the EGT under control. It helps a lot if you tow/haul with power upgrades like injectors and a chip. Without the IC, I had more power than I could use because I was limited by my EGT, with the IC I can flog my rig much harder while keeping EGT at or below 1200. An IC is not really a power adder, but if you have other power adders it will help you more fully utilize them before EGT gets out of hand. My towing mileage is worse with the IC because instead of slowing down, shifting down, and turning my chip down on big hills I can now hammer it with no EGT worry.
doug70
Sep 4, 2010 07:40 PM
doug70
Mar 19, 2010 09:59 AM
steisler
Modular V10 (6.8l)
46
Apr 24, 2009 09:10 PM
DougD
Nov 21, 2004 12:34 PM
dougg
May 6, 2004 11:47 AM
