Sponsored by: Real Truck
spark plug blew out!!!!!!!!!!!
Old Feb 11, 2010 | 06:38 PM
spence107's Avatar
spence107
I have a 99 F250 with the V-10, a sprk plug blew out of the head today, I found a kit to repair the threads, it says I need to remove the head, If I use some grease on the tap, do I NEED to remove the head, and how successful is this? and what do I need to know?
Old Feb 11, 2010 | 06:48 PM
Monster-4's Avatar
Monster-4
Old Feb 11, 2010 | 06:54 PM
mojo1's Avatar
mojo1
I had a 02 F150 that did that, I carried to a local shop and they repaired mine without removing the head. It did not take them very long. I do not know how well it held up because I traded it the next week for the F250 that I had wanted.
Old Feb 11, 2010 | 07:50 PM
bill11012's Avatar
bill11012
Modular motor junkie
It does not look like a big deal to fix, why does everybody act like it is?
Old Feb 11, 2010 | 07:55 PM
spence107's Avatar
spence107
because not everybody has alot of money to rebuild the engine if something goes WRONG!!!
Old Feb 11, 2010 | 08:01 PM
FishOnOne's Avatar
FishOnOne
Agreed...The expense to repair this type of problem should be on Ford's nickel. Completly unexceptable design!
Old Feb 11, 2010 | 08:06 PM
bill11012's Avatar
bill11012
So am I just lucky?
I beat the hell out of my V10 and have not blown a plug.
Old Feb 11, 2010 | 09:10 PM
Baja16's Avatar
Baja16
i've been told they only do that if they aren't torqued correctly....
Old Feb 11, 2010 | 09:15 PM
mojo1's Avatar
mojo1
Mine blew out on my 02 5.4 at 118,000 still with original plugs.
Old Feb 11, 2010 | 09:46 PM
FishOnOne's Avatar
FishOnOne
Originally Posted by bill11012
So am I just lucky?
Google Triton blown spark plugs and decide for yourself...
Old Feb 11, 2010 | 11:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
So am I just lucky?
It depends on how you look at the problem.
Earlier years of 2V engines had a design flaw where there was a minimal thread count in the spark plug hole. The engines (4.6L, 5.4L and 6.8L) blow out spark plugs more frequently than other engines.
Having said that, you also have to realize 2 things
First, that the majority of these engines will not blow out spark plugs. Why do you hear about it so much? The reason is because owners do not complain that their spark plugs didn't blow out
Second, that the spark plugs usually blow out AFTER the plugs have been changed (which is a strong indicator that perhaps the procedure for changing the spark plugs was not followed properly).
Old Feb 12, 2010 | 06:30 AM
spence107's Avatar
spence107
changing the plugs should be straight forward, I changed them about 50K miles ago ,is there something I should know ?
Old Feb 12, 2010 | 11:26 AM
bbender85's Avatar
bbender85
the torque specs!! and have a good torque wrench on hand to seat them. with taper seat spark plugs, your margin for error is very small when it comes to getting it right... and it's very important to get it right on our motors.
i've had 2 blow out on me so far. job isn't hard, just verrrry nerve-racking, in fear of dropping aluminum chips into the heads or not seating the insert correctly (talking about a repair w/ head on obviously). you can do it, just be careful and take your time.
Old Feb 12, 2010 | 01:17 PM
bill11012's Avatar
bill11012
I did the spark plugs on mine and never used a torque wrench, just used a ratchet.
You guys are starting to make me worry!
Old Feb 12, 2010 | 01:39 PM
bbender85's Avatar
bbender85
i did too. the first plug that blew went before i changed the plugs (not sure if they were changed before i owned it), then the scond one went out earlier this winter. i changed the plugs last summer.
it's kind of a pain in the rear to get to the rear plugs, but it's probably worth half a saturday to go thru and check them all with a torque wrench... that's what i need to do. beats fixing a blown one!
