Turn Signal Cam
So I just pulled the steering wheel off and there is the cam, held by a little stud thing. But i cant figure how to get it out of there with out prying on it and breaking something or destroying the stud and not being able to get the new one to hold in place. I did a search but didnt find anything on how to get it out of there. I got the clip of the stud but cant figure out how to get the old cam out of there. So my question is how do i get the old cam out of there without breaking anything? And if the old one isnt physically broken do i need to replace it? If anything i would like to take the old one out and clean the connections because they are all pretty scummy lookin.
The truck is a '78 F150 no tilt or cruise control. Thanks in advance, any help is extremely appreciated. FTE Rules!!! lol
What year's switches will work in the '78? Numberdummy?
There is a junkyard relatively close and very cheap i could probably get one from but before i drive all the way there and get it I want to make absolutely sure that it will work. Please help I need to get these figured out asap. Im currently out of a vehicle (see 81 in sig) and this dent will be my dd. although im dreading the thirsty 351m.
I'm doubtful the turn signal cam alone will solve your problems as it is strictly for turn signal cancellation. Maybe you are referring to the entire turn signal switch? The cam is the white piece mounted onto the switch.
The full switch comes out rather easily once the steering wheel is off - except for the wiring. If you replace the entire switch you'll need to fish the wires from the new switch through the steering column - pretty much a pain in the a** (recommend you pull the protective sleeve out from the lower base of the column and feed the wires through there after you get them through the column with a clothes hanger).
I got a new switch from rockauto for around $45. Came with fitments already crimped to each wire that popped into the OEM connector under the dash.
Mine is a '77 250, so your switch may be slightly different.
