Sponsored by: Real Truck
Adding led running lights above step??
Old Feb 11, 2010 | 03:53 PM
rjfetz1's Avatar
rjfetz1
Not sure I like the recon "big rig" look of running lights the whole length of the steps. I was thinking maybe 2 led lights Maxxima® Chromed Bezel Oval LED Clearance Light - Yellow - Mfg# AXP5Y-KIT
on each side (front and rear bracket) of the mounting brackets of the ford oem chrome steps here...
not the best pic..its my first... but you get the idea. Its flat, and 6" wide. What do you think??
Where would I tap into running lights??
Old Feb 11, 2010 | 08:23 PM
03silverTJ's Avatar
03silverTJ
You can tap into either the Tail lights, or the parking lamps on the front. You could even tie them into your blinkers!
Old Feb 12, 2010 | 06:23 AM
rjfetz1's Avatar
rjfetz1
Parking lights up front sounds like the place to tap into.
Funny thing.. no one has any opinions... however if I do it and they look great...everyone will want to see pics
Old Feb 12, 2010 | 08:29 AM
patrickke's Avatar
patrickke
Well I think they will look much better than the big rig look imho
Old Feb 12, 2010 | 10:55 AM
ecky's Avatar
ecky
All right. I am no good with computers so hopefully it worked. I added two pictures in my gallery album leds, at least I hope. My truck is a CC so I put 6 lights on each side. I first got a piece of aluminum flat bar and mounted it under the doors using the cab step bolts. Measured everything to get my spacing, and marked the first one. Took the alum. bar off the truck and marked the other lights. I did set the lights on just to see if everything was ok. Drilled holes for the mounts, bar went back on truck, used a small bit and drilled pilots for some ss self-tappers for the mounts. Oh yeah, forgot to mention drilling holes for the wires, so I had three holes for each light. Used some grommets, wired them up and I actually ran them to the 4-pin connector. When towing, I always use the seven-pin so it was no biggie. The only problems in 4 years was twice I had the wires corroded right at the plug end of the light harness due to road salt getting in there, easy fix though.
ecky
Old Feb 12, 2010 | 11:58 AM
Firekite's Avatar
Firekite
Nice concept, ecky. Any night shots?
Old Feb 12, 2010 | 07:16 PM
ecky's Avatar
ecky
no night shots yet but i'll get one this weekend
Old Feb 12, 2010 | 07:31 PM
spinella's Avatar
spinella
ecky
looks good. the install looks clean and you covered the ugly pinch welds. did you consider using a washer in between your mounting plate and the truck body. i'm thinking that you would be able to get the road salt out from behind the mounting plate. post some night pics when you get a chance.
Old Feb 12, 2010 | 07:56 PM
_Rick_'s Avatar
_Rick_
ecky,
Nice job on the running board lights. Looks similar to what I have planned for my Truck. I'm probably going to go with white lights (are yours yellow running lights?).
I am looking forward to seeing how yours look at night.
I just want mine to come on when the doors are open to help passengers see the kodiak steps for safe exit and entry into the Truck.
Rick...
Old Feb 13, 2010 | 07:24 PM
ecky's Avatar
ecky
Night pic added, some glare but ya get the idea. Mine are the amber lights. I'm not sure what wire to splice into so they come on when the doors are open, but it shouldn't be too difficult to find out.
Old Feb 13, 2010 | 08:18 PM
_Rick_'s Avatar
_Rick_
ecky,
It will be easy for me when the time comes. I pre-wired for the step lights when I replaced a motor (stripped gear) in one of my 4 Kodiak steps. I serviced the other 3 steps at the same time so I got them all ready for lights. By design,,, only the light above each individual step will come on when a door is open.
re: night photo...
The yellow running board lights look bright. It looks like you have them hooked up to your head/parking lights? or is there a door open on the drivers side I can't see in the photo?
Rick...
Old Feb 14, 2010 | 09:26 AM
ecky's Avatar
ecky
They are hooked to the parking lights. They are pretty bright. My one younger brother hates it while the other one loves it.
Old Mar 13, 2010 | 12:19 PM
Firekite's Avatar
Firekite
Come on, man, it's been over a month. Let's go. I want to see what they look like!
Old Mar 13, 2010 | 02:25 PM
Citypol86's Avatar
Citypol86
...I added two pictures in my gallery album leds...
Looks really nice! I had standard-bulb marker lights there also but I mounted them right on the pinch weld piece. When I raised the factory steps it blocked them and now you can't see them. You can see the glowing light though. I occasionally think about where I can move them to so that you can see them.
Nice work.
Later...
Brewster...
Old Mar 14, 2010 | 06:25 AM
smithrngr's Avatar
smithrngr
totally missed this thread,i put the recon big rig markers along my running boards and the look great.i tied into the front parking lights,and hooked up the turns too.my truck is a 2001 so i have the bug plastic running boards and they still look good.mine even blink when i hit the alarm button on my keryfob.i can try to get some pics tonight if anyone wants see them.
