1978 - 1996 Big Bronco
help with vin number
Old Feb 11, 2010 | 12:32 PM
Primed67's Avatar
Primed67
I have tried several times to run the vin and it keeps telling me it's an invalid number. The vin number is 1FMDU15N0FLA80791. I figured it may be wrong so I went and looked on the door panel and the number is right but it looks like there could have been a number or something before the 1. I don't have a titile to it so I can't look on it. Does anyone have a clue? Thanks!
Old Feb 11, 2010 | 03:12 PM
greystreak92's Avatar
greystreak92
Its a gasoline-using 1985 Bronco with a 302 (5.0) V8 assembled in Michigan, USA. THIS VIN CALCULATOR had no problem with it.
Old Feb 11, 2010 | 07:29 PM
Primed67's Avatar
Primed67
Thanks for your help!
Old Feb 11, 2010 | 10:28 PM
Primed67's Avatar
Primed67
One more thing, Is there a way to tell what gear is in the truck by any of those numbers or the numbers on the vin tag?
Old Feb 11, 2010 | 10:58 PM
greystreak92
Axle gearing can be determined from the tags on the axles themselves. Transmission gearing you will have to research if you want to know what each ratio is for the transmission in that truck.
Old Feb 11, 2010 | 11:28 PM
Primed67's Avatar
Primed67
Thanks again I appreciate your help!
