Shaking while turning.
Old Feb 11, 2010 | 05:20 AM
sleek122's Avatar
sleek122
I just picked up a 03' Aviator for my wife and just noticed the other day that when you turn sharp left the steering is shaking. I did a search and didn't get much. Has this been brought up before? I haven't been able to look at it yet and just trying to get some Ideas of what to check. I don't believe that it happens when turning right but not 100% sure. Thanks in advance for all input.
Old Feb 11, 2010 | 07:00 AM
shorod's Avatar
shorod
Does it also do the shaking if you turn the steering hard left while the vehicle isn't moving? It could be air in the power steering, it could be a problem with the electric assist (assuming the Aviator has electric assist as well), or if it's only when moving it might be a suspension issue. Every hear clunks or pops when driving over bumps in the road?
-Rod
Old Feb 11, 2010 | 07:53 AM
jrgoffin's Avatar
jrgoffin
My Aviator does this a bit too, only when you have the wheel turned all the way to the left and at slow speed (i.e., pulling in to the driveway). The previous owner let the power steering fluid get real low, so for now I figured there was some air in the system. It will be one of my spring projects.
Old Feb 11, 2010 | 08:19 AM
sleek122's Avatar
sleek122
-Rod
I haven't tried it while it is sitting, just noticed it while driving doing a u turn. Is the power steering not a self bleeding system on these vehicles? I would imagine it has the electrical assist, it has some sort of progressive steering type thing (can't think of the words) I will have to do some more trouble shooting on it next week and find out if it does it while parked. Never heard clunks or pops over bumps.
This sounds like what I am experiencing and if you figure anything out let me know.
Old Feb 11, 2010 | 01:28 PM
shorod's Avatar
shorod
The term I'm familiar with for Ford is Variable Assist Power Steering (VAPS). I'm not sure if the hydraulic system is truly self bleeding. I've read of several methods to help bleed it so if may be marketed as self bleeding even if it doesn't completely live up to that description.
You might also have binding from CV joints or a transfer case that is stuck in 4WD, but I think the Aviator is AWD rather than 4WD.
-Rod
Old Feb 12, 2010 | 01:50 AM
sleek122's Avatar
sleek122
-Rod
Thanks thats what I was trying to think of. I would like to know what methods to bleed the steering.
The Aviators are considered AWD but I just have a regular 2 wheel drive, so no chance of anything like that.
I am gona try to look at it on Mon. to do some more looking at it. If anyone has any other sugestions please let me know.
Old Feb 12, 2010 | 06:57 AM
shorod's Avatar
shorod
You'll probably get a battery answer than what I remember if you search the forum. I think the location I saw the bleed process was on a different forum (which I won't mention here). I recall that it involved something like getting the front wheels off the ground and the PS reservoir higher than the rest of the steering system, then slowing turning the steering wheel from lock to lock, holding at lock for about 2 seconds each direction. Maybe I read that on a Ford Taurus forum.... Anyway, another way would be to remove the return line from the pump, hold it in a jar, and have a second person standing near to keep the reservoir topped off. Run the engine until you no longer see evidence of air in the fluid from the return line.
-Rod
Old Feb 12, 2010 | 12:58 PM
izoomie's Avatar
izoomie
This may be a silly answer but have you checked the tires for balance or a slipped belt. You could move the fronts to the back and see if it continues.
Old Feb 23, 2010 | 05:44 AM
sleek122's Avatar
sleek122
Update
O.K. I got a chance to look at it this last weekend. I put it up and checked the front end. Looks like the ball joints, tie rod ends, and A arm bushings/bearings are good. Everything seems to be tight and no play anywhere I could see of.
I also took it to test it again and it seems if you are going slow turning it doesn't shake. It is also doing it when I turn right. It starts to shake when you are at or almost at full turn left or right. The only time it does it is when driving, I can turn the wheels when sitting and it just has a little whine in the power steering. Could this be the power rack causing this problem? Right now I am at a loss on what could be the problem. I still want to take it to an alignment shop and have them look it over but not sure if they will find anything either.
7283-F250
1983 - 2012 Ranger & B-Series
Jun 5, 2016 02:19 PM
2008F250SHAKING
Dec 28, 2015 12:12 PM
Wes Shaver
2004 - 2008 F150
Nov 28, 2015 09:03 PM
Bigd1975
2004 - 2008 F150
Sep 24, 2015 11:29 AM
QwkTrip
2009 - 2014 F150
Nov 28, 2012 12:35 AM
