Sudden backfiring?
Old Feb 12, 2010 | 01:17 PM
Julies Cool F1's Avatar
Julies Cool F1
See if it starts when it's cold. If it does, replace the coil.
A coil going out will cause the truck to run like it's running out of gas - backfiring and all, then it just dies.
A coil going bad will run when it's cold and as soon as the engine gets hot, it will die. Starts righ back up again when it cools off.
Happened to me - just a thought.
Old Feb 12, 2010 | 02:02 PM
Stephen67's Avatar
Stephen67
Thanks, hopefully thats the problem, it would make sense as it's been having these problems when it's been running pretty well on the highway for a little bit.
Old Feb 12, 2010 | 03:42 PM
fatfenders56's Avatar
fatfenders56
Check for intake manifold/gasket leaks, spray some choke cleaner around the mating surfaces while it's idling, changes in idle speed/smoothness will tell you when you hit the bad spot. LOL
Old Feb 15, 2010 | 12:48 PM
Julies Cool F1
Ever figure this out?
racer7x
3.8 & 4.2L V6
May 17, 2015 05:32 PM
shanes66charger
Nov 3, 2013 08:18 AM
F4L956
1997 - 2003 F150
Jun 10, 2010 09:16 PM
XolieX
15
Oct 30, 2005 03:56 PM
bobonut
Jan 11, 2005 12:33 AM
