Steering column concern
Old Feb 10, 2010 | 11:46 AM
76F100guy's Avatar
76F100guy
When I turn the steering wheel slightly right of center, there's a "click" in the column (which I can feel in the wheel), like a loose joint or pin. If I go under the hood and hold the rag joint while an assistant works the steering wheel left to right and right to left, we can definitely feel something loose within the column. It's not a lot, but any is not good. Suggestions? It's a 2WD.
Old Feb 10, 2010 | 12:03 PM
montana_highboy's Avatar
montana_highboy
There's an upper and lower bearing inside the column, possibly one of them are making the noise you hear.
Old Feb 10, 2010 | 09:25 PM
76F100guy's Avatar
76F100guy
There's a very slight amount of up/down play that I'm pretty sure is due to the upper bearing. The play I'm concerned about is circurferential, as I turn the wheel to the right from center, I can feel it "click". It's somewhere between the rag joint and the steering wheel. I'm not sure how the steering shaft is constructed, which is why I'm asking the question.
Old Feb 11, 2010 | 10:01 AM
4x4 Bart's Avatar
4x4 Bart
Pull your steering wheel and Three screws holding your turn signal switch. Then you will have access to your upper bearing. You will be able to check for the click and find it. If it's not there it would have to be the lower bearing.
Old Feb 12, 2010 | 10:59 AM
76F100guy's Avatar
76F100guy
Thanks, I'll take a look. I'm sure this will take care of the up/down and side/side, but I still think there's something wrong with the column itself. I guess the best way to describe the "click" would be as 1/4" of free play at the wheel.
