questions
Old Feb 9, 2010 | 11:03 PM
TTFord07's Avatar
TTFord07
questions
Has anyone just put the superduty injectors right into their truck? and did it run ok? Second I know it easy to put the intercooler and such from a super duty on but has anyone but on a super duty turbo too?
Old Feb 10, 2010 | 07:13 AM
427 fordman's Avatar
427 fordman
If you do the sd turbo, from what I read its not a lot better than ours (except for quicker spool up but has higher egt's), but there are more options to use with that setup to upgrade. You'd need to change the pedestal, intake plenums and spyder of course. I know some run sd injectors, but don't know if pcm needs upgrading to work with them or what.
Old Feb 10, 2010 | 12:08 PM
drivembig's Avatar
drivembig
I believe that you have to have the IDM mod done. I.E. the 140v IDM
