axle swap ????
Old Feb 9, 2010 | 08:55 PM
fromm's Avatar
fromm
axle swap ????
Will a rear axle from a 76 ford 1/2 ton 4x4 fit on a 79 ford full size bronco
(spring width and frame width)
Old Feb 10, 2010 | 12:35 PM
Ford_Six's Avatar
Ford_Six
Yes and no- The Bronco axle was the same width as the old pre-72 F100 rear axle, so the new one will stick out a little further. Otherwise it should be pretty direct, even if it's not moving perches is easy.
