Offroad & 4x4
Dana 60s
Old Feb 9, 2010 | 08:41 PM
dillinewton's Avatar
dillinewton
Dana 60s
Hey there, i have been looking for a front dana 60 and found a matching set with 4:10s in them for $1000, think thats a good deal?
Old Feb 9, 2010 | 08:46 PM
dragogt's Avatar
dragogt
King pin or ball joint??
Either way that a good deal in my area...
Old Feb 9, 2010 | 09:03 PM
dillinewton
king pin i think its a 79 fo perfect for my coil spring conversion on my 79 ford f150
Old Feb 9, 2010 | 09:05 PM
dragogt's Avatar
dragogt
Do it.
(gd10cl)
Old Feb 9, 2010 | 09:06 PM
alpha/omega's Avatar
alpha/omega
78/9 D60 front is worth $1000 alone. The rear...eeeh $100-150
Old Feb 9, 2010 | 09:11 PM
Prozon's Avatar
Prozon
You've got yourself a deal.
D60's around here run anywhere from 800-1200 bucks. The rear about 150.
Old Feb 9, 2010 | 09:25 PM
dillinewton
well sweet im gonna try to go get them this weekend if i dont snow too much
Old Feb 9, 2010 | 10:09 PM
73 ford guy's Avatar
73 ford guy
Sounds about right for the $. Get ready to spend lots of money in building it. Ive got bout $4000 into mine.
-$500 axle(cheap)
-crossover steering$500
-hydro assist $400
-Detroit locker$700
-gears/install kit $500
-rotors,wheel bearings$200
-35 spline stub axles/ujoints$500
-warn premium 35 spline hubs $310
-warn stainless skid plate$100
-tie rod over flip$100
no additional costs on labour I did it all icluding gear setup which was my first time and has had no issues after hard abuse
Lots of fun depending on how far you want to go
Old Feb 10, 2010 | 02:33 AM
captain p4's Avatar
captain p4
Resell that poo poo rear d60 to some unsuspecting newb once you buy 'em and get yourself a sterling or a d70
Old Feb 10, 2010 | 06:36 AM
fishmanndotcom's Avatar
fishmanndotcom
make sure its a D60 rear first before selling it. i have heard some ppl have mistaken a D70 to be a D60
-cutts-
Old Feb 10, 2010 | 06:57 AM
dillinewton
well my plan so i can get this truck is only to lock the rear right now, and i tihnk im just gonna stick with 4:10s because i still wanna be able to drive the truck around easily. also i was looking at the add again and it said the rear is a 80' sterling, not quite sure what that is... i have herd people talk about there sterlings on here, but im not sure if its the same one or not? thanks alot............ya i just talked to the guy on the phone and he said he thinks its a sterling 10.25 is that a good set up?
Old Feb 10, 2010 | 09:06 AM
alpha/omega
Id be cautious that it is/isnt a matched set.
Sterlings werent available until 87 (I think), predating the "king pin i think its a 79" by 8 years. Nothing wrong with the later kingpin D60s but the 78/9s are far more valuable.
The driver side axle tube is longer on the 78/9.
Old Feb 10, 2010 | 09:47 AM
dragogt's Avatar
dragogt
Might want to do yourself a favor and post pics of said axles if you can; That way you know exactly what your getting.. jmo
Old Feb 10, 2010 | 10:03 AM
oldmansimek's Avatar
oldmansimek
If they are a match set (out of the original vehicle) and that rear is a sterling, It is out of a 86 or up, the sterling will bolt into 70's-90's trucks so it could have been swapped in at some point. You need to make sure, because the pumpkin is in a different spot on the newer trucks. it is about 4-6 inches further to the left then the 70's. The 70's up until 91-92 all have kingpins and other then the placement of the pumpkin there is no strength difference nor is one better then the other unless it will not fit your application
Old Feb 10, 2010 | 11:20 AM
dillinewton
well here they are so what do i have, he said there matching but the rear is out of an 80's and he said the front is out a of 79 so i dont know why he would put there matching idk what he ment by that, but here they are. so what do you guys think?
